Redoing ac 09 tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrenchRiver, Aug 25, 2020.
  1. Aug 25, 2020 at 6:25 AM
    FrenchRiver
    FrenchRiver [OP] Member
    Nova Scotia
    2009 tacoma 4x4
    stock
    I have read posts but still confused regarding the addition of compressor oil to the system. After measuring the oil in the old unit and adding the same to the new comp, do I add the required oil directly into the new condenser? Is blowing compressed air threw the system after removing the comp. enough to remove junk? Thanks for any help with this, if I font,t get it fixed it will be driving with the endows down, to much money for a shop visit.
  2. Aug 25, 2020 at 10:42 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There are plenty of choke points that accumulate debris. The expansion valve is the main one. Blowing air through the system with them connected can plug it up.
    Also, any time you open the system, you should replace the dryer. The dryer's desiccant can only absorb a small amount moisture(moisture ices and plugs the system), and be saturated by the moisture in the air while you work. Running a vacuum on the system will not remove the moisture from the desiccant.
    Anytime you disconnect a joint, replace the O-rings. They are not reusable.
