Redside Electric Plug-and-Play Switch Illumination Harnesses
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by kmorgan3, Dec 3, 2020.
  1. Dec 6, 2020 at 9:20 AM
    Cappy
    Cappy Well-Known Member
    Georgia
    Gotcha. My ch4x4 switch is already connected but I'm not 100% sure how I wired it. I believe the illumination wire is attached to an add a fuse to the tail lights fuse so it comes on when the lights are on but the dimmer doesn't change the lighting. I'm assuming that if I take that wire and attach it to your + wire then attach your - wire to the switch that everything will continue to operate properly while being able to dim the switch with the dash lights. Is this correct?
  2. Dec 6, 2020 at 10:24 AM
    kmorgan3
    kmorgan3 [OP] Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Yep!
  3. Dec 6, 2020 at 1:11 PM
    Cappy
    Georgia
    That's good to know. One more question. How many switches can be added to this without causing issues?
  4. Dec 6, 2020 at 1:27 PM
    kmorgan3
    Kyle
    PNW
    I know people that have run 6 switches off of even smaller connectors. Right now I have 5 and no issues. LEDs are very efficient.
  5. Dec 6, 2020 at 1:29 PM
    Cappy
    Georgia
    Awesome. I don't plan on that many for sure. I'll bite so add me to the list and let me know when its available and how to send payment. :thumbsup:
    kmorgan3[QUOTED][OP] likes this.
  6. Dec 6, 2020 at 1:33 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I'm in for a second generation tacoma version!
    308savage likes this.
  7. Dec 6, 2020 at 1:34 PM
    kmorgan3
    Kyle
    PNW
    Does the 2nd gen have the same plug? Can you take a picture of it for me?
  8. Dec 6, 2020 at 1:35 PM
    ramonortiz55
    Ramon
    Texas
    stock
    I need to find out where the plug youre referencing is at first :)
  9. Dec 6, 2020 at 1:35 PM
    ramonortiz55
    Ramon
    Texas
    stock
    but i can find out for you
  10. Dec 6, 2020 at 1:44 PM
    LJTacoma
    LJTacoma My Ferrari...
    Erik
    2020 Toyota Tacoma TRD Off-Road 4x4 2+2 (voodoo blue)
    Two (dumb) questions:
    1. Where (precisely) does this plug into the existing harness?
    2. Is there a relevant difference for different gens (I have a 3rd gen)? Thank you.
  11. Dec 6, 2020 at 1:50 PM
    kmorgan3
    Kyle
    PNW
    I don’t think 2nd gens have it. You could try to tap the neighboring traction control switch. Solid green is the Ill (+) and green with white is the variable Ill (-). I’d have to track down connectors if there was demand for it. It’s not a connector I’ve seen on my truck.
  12. Dec 7, 2020 at 2:55 PM
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    I’d be in for one that taps the cargo lights so I can run a bed light.
    RTedder2 likes this.
  13. Dec 7, 2020 at 5:32 PM
    NukedTaco
    Wyatt
    The switch you have circled is what controls the cargo light in the 3rd brake light assembly. I’m looking to add a bed light that is controlled by that switch since my 3rd brake/cargo light are blocked by my softopper.
    AMSK.505 and kecknj like this.
  14. Dec 7, 2020 at 6:12 PM
    kmorgan3
    Kyle
    PNW
    Good news: I was able to up my raw materials order. So for folks that were on the wait list for the 2nd batch you will be included in the first batch. We may be delayed by a few days on the ETA so take the current estimate as a rough estimate. However, I’m happy more people will get to be in the newest batch.
    kecknj likes this.
  15. Dec 7, 2020 at 7:16 PM
    #35
    Newlyofftheground
    Newlyofftheground Active Member
    Jeffrey
    2020 Taco Off Road
    Just got it yesterday lol
    Please sign me up
    kmorgan3[OP] likes this.
  16. Dec 8, 2020 at 5:47 AM
    #36
    caribe makaira
    Caribbean, Puerto Rico
    That would be correct IF the added lamps also have a relay. Don't add the ground from the added lamps to that wire unless you want to sizzle the Combo Meter.
  17. Dec 8, 2020 at 6:44 AM
    #37
    kecknj
    kecknj Well-Known Member
    Nick
    '19 TRD Off-Road
    There is a relay on that diagram...
  18. Dec 8, 2020 at 7:17 AM
    #38
    caribe makaira
    That is correct. It's the relay that provides fused power to the cargo lamp. Notice that the wire to the switch is from the relay coil...
    kecknj[QUOTED] likes this.
  19. Dec 8, 2020 at 7:27 AM
    #39
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    The OEM fog light mod I did for my SR I tapped off the ground pin of the cargo connector for the pin 26 to ground instead of running a separate ground wire. Also tapped the illumination pins.
    Suggestion:You might consider tapping off all cargo connector pins and folks can use what they want and tape off or remove the ones they don’t.
  20. Dec 8, 2020 at 7:39 AM
    #40
    kmorgan3
    Kyle
    PNW
    I could do that, however the intention of this harness (before folks asked for custom stuff) is just to illuminate extra switches. :rofl: I make these by hand and would prefer not to have to double crimp 6 pins for a breakout vs 2. That is unless people want a bit of an up charge. If it were a machine doing it it wouldn’t be that bad.
    TRok and kecknj like this.
