Reducing rear sag with Towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rbenner89, Oct 17, 2018.
  1. Oct 17, 2018 at 6:27 AM
    rbenner89
    rbenner89 [OP] Well-Known Member
    NY
    '10 man tran TRD SR5
    Towed a travel trailer this weekend (sport with tow package) for the second time with a weight distribution hitch and swaybar and it wasn't bad. The trailer is definitely under max weight of 6500. The tongue weight is heavy though. I am having quite a bit of sag on the rear suspension (did the rear leaf TSB) and wondered if anyone had suggestions on improving the rear sag so she sits more level... Seen some posts on sumo springs...any suggestions welcome
    thanks
  2. Oct 17, 2018 at 6:31 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Even with the TSB the rear leafs in these trucks are junk.
    If you aren't going to lift, I'd go with airbags. Deaver makes some standard ride height higher capacity springs afaik, though they're going to make your truck ride a lot stiffer.
  3. Oct 17, 2018 at 6:32 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I second airbags. Firestone makes a set for the truck for around $300-$400 IIRC
  4. Oct 17, 2018 at 6:37 AM
    Lordaca
    Lordaca Well-Known Member
    Melbourne, FL
    TRD SPRT DC LB 4x4
    Weathertech floor liners and wind deflector, OEM roof Rack, Wet Okoles seat covers, cb installed
  5. Oct 17, 2018 at 6:40 AM
    rbenner89
    NY
    thanks for the info- how heavy is your trailer?
  6. Oct 17, 2018 at 6:47 AM
    Lordaca
    Melbourne, FL
    TRD SPRT DC LB 4x4
    I figured it weighs about 5000lbs with 500lbs of tongue weight. I have been meaning to go to the scales and get exact numbers but we are usually dont have the extra time to do so. Below is without the sumo springs and I will try this weekend to get it one with them installed.
  7. Oct 17, 2018 at 7:02 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Is your WD hitch setup properly? I get very little sag when mine is hitched up with a WD hitch...even when I was running stock suspension. (Trailer is 4,500 dry with a 450 lb dry hitch weight).
    ColoradoTJ and Phoosa like this.
  8. Oct 17, 2018 at 7:12 AM
    rbenner89
    NY
    thanks that would be great- your rear sag looks a bunch like mine does now. I think my tongue weight is a bit more.IMG_1902.jpg
  9. Oct 17, 2018 at 7:15 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Do you have stuff in the bed of the truck in that pic? I have the same trailer and don't sag nearly as much.
    I'm guessing that your WD hitch isn't properly setup.
  10. Oct 17, 2018 at 7:18 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Your tongue weight shouldn’t be exceeding the max allwance of 700lbs. So obviously verify your trailer is loaded properly.
    Rear leafs in these trucks suck and they will sag with heavy hauling and towing.
    You will want to look into some sort of suspension upgrade. Air bags, AAL, the Toyota TSB pack, or new leaf springs like a pack of heavy duty Dakars.
  11. Oct 17, 2018 at 7:18 AM
    iitywygms
    iitywygms Well-Known Member
    Norcal
    4x4
  12. Oct 17, 2018 at 7:28 AM
    rbenner89
    NY
    Will check the WDH setup and lower maybe a bit. There wasn't a ton in the bed but some gear. If I add a leaf in the rear do I have to do anything in the front?
  13. Oct 17, 2018 at 7:30 AM
    rbenner89
    NY
    Is there a "procedure" for correct WD hitch setup?
    EDIT: found some on this procedure but any hints are welcome
  14. Oct 17, 2018 at 7:36 AM
    rbenner89
    NY
    Sticky Taco Do you have a close up pic of your ball/hitch setup?
  15. Oct 17, 2018 at 7:43 AM
    Lordaca
    Melbourne, FL
    TRD SPRT DC LB 4x4
    @stickyTaco do you have Dakar leaf springs? I feel you cant compare when he has as the stock leaf springs. They are junk and have a hard time with very little weight.
    @rbenner89 Even if you WDH is setup properly you are going to get squating with the OEM springs. This is why I went with Sumo Springs as a quick fix. A true fix is replacing the leaf springs with better ones.
  16. Oct 17, 2018 at 7:49 AM
    rbenner89
    NY
    Going to more accurately setup the WDH and see how bad the sag is (this trailer has a heavy Tongue weight). Maybe Sumo springs temporarily as an add also... we'll see
  17. Oct 17, 2018 at 7:51 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    4 wheel parts had them in stock for my truck, and they price matched Amazon
  18. Oct 17, 2018 at 7:51 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    I got Sumno springs and now have level towing my 4200# camper. This is how I load my WD hitch: With the hitch latched on the ball, I lower the tongue jack until I can see the back of the truck starting to rise up. It is essentially pulling up the back of the truck. Then I hook up the two torsion bars on either side of the hitch and lower the jack until all the weight is on the ball. Nice and level. Also as was noted above, might want to drop the ball a bit.
  19. Oct 17, 2018 at 7:54 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Airbags with automatic leveling kit.
  20. Oct 17, 2018 at 7:59 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Stock leafs are junk, if you tow a lot, do yourself a favor and get better leafs.....
    Dakars are great for towing but add around 3" of lift and sag about 1" with the trailer on. So you net about a 2" lift with a trailer and gear.
    Some other leafs are good with less lift, 1-2" is good so it levels out with the trailer.
    An OME lift with 884 in the front is what I ran for 3 years. Great for towing with my 16X7 inclosed trailer, about 5,000 pounds loaded... Running AT3s 275 70s
    I towed this trailer for 9 years with stock 4runners and the Tacoma, when I put the lift on It was night and day better for towing. The lift turned it into a truck. I was pissed I never did it sooner...
    Johnnyk33 likes this.
