Redundant question time: will these wheels and tires fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by slobmonster, Apr 20, 2016.
  1. Apr 20, 2016 at 3:28 PM
    slobmonster
    slobmonster [OP] Active Member
    California
    00 Tacoma XCab 4WD
    I'm looking to trade wheels & tires with a friend of mine, as she could give a crap and seems amenable to my smaller wheels and an extra few hundred bucks for the trouble.
    I have a 2000 Tacoma X-cab SR5 4X4, wheels are stock 15".
    My friends tires are 165/65R17.
    Will these fit without spacers or any other shenanigans?
  2. Apr 20, 2016 at 11:34 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    depends on what year her truck is... in theory 265/65/17 is slightly wider than your stock 245/75/15... assuming hers are from a newer tacoma, the backspace is different... yours is about 4.5" and hers is around 5" or so... if you can get her to let you test fit, that would be best...
  3. Apr 20, 2016 at 11:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You better do a test fit. I'm betting the 15's are not going to work on her truck.
  4. Apr 20, 2016 at 11:43 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    x2
    i completely forgot about the girl... always been my problem... ahem
    anywho, yah, the newer tacomas can't fit anything smaller than 16" wheels...
  5. Apr 21, 2016 at 7:55 AM
    slobmonster
    California
    00 Tacoma XCab 4WD
    Thanks everyone. So she has a 2006 or 07 Runner. Will see if we can do a quickie swap on one of the fronts to check for fit. For the life of me I can't intuitively understand why a smaller wheel would not fit, but I'm hearing y'all.
    (I did go down the wheels & tires 37-page rabbit hole last night, and appreciate your time)
  6. Apr 21, 2016 at 8:15 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    I believe the brake caliper size and/or brake vein location is the issue. If you want to avoid liability messing up her truck, may be best to err on the side of caution.
