Redundant Suspension Question
Discussion in 'Suspension' started by Rookie305, Mar 1, 2013.
  1. Mar 1, 2013 at 6:36 AM
    Rookie305
    Rookie305 [OP] Member
    JC
    Sunny305
    TRD Project
    Work in Progress
    This is were I need a bit of suggestive help. I live in South Florida, no hill or 4 wheeling. After 1 year with my truck, I would like to give it a bit of a lift. I am really not sure at all even after reading posts which way to go. I do not need a massive suspension system, 1) because it out of the budget now, and 2) all I need it for is looks. I was think of get spacers and blocks but it sounds like that is the wrong way to go. so I was thinking of going with Pro-Comp 3 inch lift with shocks K5081B. I was also looking at the Bilstein Adjustable lift kit w/ 5100's BK0510 but is about $200 more.
    Any and all help and suggestions will be appreciated :D
    JC
  2. Mar 1, 2013 at 6:41 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I would get the billys. Everyone has them, becuase there relatively inexpensive for the quality of shock you are getting, they lift the vehicle, improve ride, and they work. I think the pro-comp also have a very stiff coil, making ride harsh.
    regardless if your not planning on offroading with them, they will still improve on road driving, and should acomplish the "look" that your going for.
  3. Mar 1, 2013 at 6:42 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the cheapest route you can go (without doing spacers) would be to add bilstein 5100's up front and an 1.5" AAL in the rear. Get an alignment and you're good to go.
  4. Mar 1, 2013 at 8:06 AM
    Rookie305
    JC
    Sunny305
    TRD Project
    Work in Progress
    Kevin-
    With the 5100's would I need to add coils, or factory are fine? Now we just talking adding the 5100's and the aal on the back and thats it. would I need to add a shock extender for the rear?
    Thanks for the info
  5. Mar 1, 2013 at 9:45 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    you can use the stock coild and adjust the billies.
    Dont think you need a shock extender.
  6. Mar 1, 2013 at 9:53 AM
    acdronin
    acdronin Well-Known Member
    Don't need a shock extender, stock coils with front billies set at 1.75 will give you a little lift in the front, the ride will be stiffer on stock coils but you'll have to decide if that's good for you. If not, then a new set of coils would improve the ride a lot more. Installing a 1.5 or a 2 inch AAL from someone like Wheeler's Off Road would bring the rear up and with billies in the back the ride will be an improvement over your stock shocks.
  7. Mar 1, 2013 at 9:58 AM
    Rookie305
    JC
    Sunny305
    TRD Project
    Work in Progress
  8. Mar 1, 2013 at 10:06 AM
    acdronin
    It's all good man, those I think look to be the rear shocks I think. the fronts you are looking for are technically called struts, but they are called shocks too, those are the Bilstein 5100 Height Adjustable Struts (or shocks).
    And It's 1.75 inches of front lift
  9. Mar 1, 2013 at 10:17 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I have no idea if that is the part # for our trucks. but no you wont need rear shock extenders if you dont plan on offroading. Even if you do wheel it a little you wont hurt anything not having them.
    If you only want to lift the front you can set the 5100's at 1.75". If you want to lift both the front and rear you would want a 1.5" aal for the rear and set the 5100's at 2.5", this would make your truck pretty much level. if you want a slight rake with the rear being taller get the 2" AAL.
    keep in mind that the higher you go the stiffer your truck will ride.
  10. Mar 1, 2013 at 4:28 PM
    Rookie305
    JC
    Sunny305
    TRD Project
    Work in Progress
    Awesome, great info...
