Reese Locking Hitch
Discussion in 'Towing' started by black98, Jun 29, 2009.
  1. Jun 29, 2009 at 5:09 PM
    black98
    black98 [OP] Well-Known Member
    Austin
    1998 PreRunner
    I bought my taco about a month ago and it came with a Reese key locking hitch on it. Unfortunately, the seller did not have the key that goes with it. I sent Reese an email, to which they actually responded saying they could not help me or send me a replacement key without having the key number or something. What can I do, short of sawing of the little metal dowel there? It is not really posing a problem right now, other than the aesthetics of the truck, but it would be nice to be able to remove the hitch. Although, it's also nice to know I have a little extra protection in case someone rear ends me.
  2. Jun 29, 2009 at 5:13 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Sawzall or a torch seems to be the fix for your problem...
  3. Jun 29, 2009 at 5:16 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    See if the guys at your local firehouse want to give their 'jaws of life' an outing.
  4. Jun 29, 2009 at 5:19 PM
    kasey200
    kasey200 Well-Known Member
    south dakota
    07 TRD Dboubl Cab Longbed
    3" toytec, 285 BFG AT's
    you may have a hard time cutting with a saw of any sort because it's hardened steel. it will just ruin the blade. use a grinder or torch.
  5. Jun 29, 2009 at 5:46 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    i had one of those exact locks on my T-100. sounded like a good idea until i actually needed to remove it. i had a key for mine, but the rust had formed an impenetrable seal on the lock. never did get it off...sold it still rusted in place...keys in glovebox. die grinder w/cutoff wheel, or a couple good bi-metal sawzall blades should do it.
  6. Jun 29, 2009 at 8:37 PM
    black98
    Austin
    1998 PreRunner
    Thanks guys, wish there was a way to just find an extra key...
  7. Jun 29, 2009 at 8:41 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Talk to a lock smith?
  8. Jun 29, 2009 at 9:03 PM
    black98
    Austin
    1998 PreRunner
    No, but it is an option, hopefully it won't get to that, are locksmith services expensive?
  9. Jun 30, 2009 at 3:14 AM
    RCBS
    Appalachia
    06 Main Runner OR
    they cost more than a new hitch lock, i bet.
  10. Jun 30, 2009 at 3:19 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    usually locksmiths do automotive key molds for something around 50 dollars
  11. Jun 30, 2009 at 8:03 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Sounds like that puppy's gotta go.
  12. Jun 30, 2009 at 9:58 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Grind it off and buy a new one for $20 at Wal-Mart.
  13. Jun 30, 2009 at 6:55 PM
    fletch aka
    Gary
    Left Coast
    To bad you don't live near Chris, not only would this lock be history, we would have a great story to pass around. :D
  14. Jul 10, 2009 at 5:03 PM
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    The fastest way I can think of is to visit your freindly body shop or metal shop that has a plasma or other gas cutting device and have them lob it off for $10.00, might be less. Of course you would loose your pin holding in the ball mount, something you would probably need to replace anyway.
    -Joe
  15. Jul 10, 2009 at 5:07 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    yea i'd say just cut it off and buy a new one. there pretty inexpensive anyways. i would use a grinder with cutoff wheel, torch or plasma for sure.
  16. Dec 19, 2014 at 2:31 PM
    agadams
    agadams New Member
    You can cut it off but when I lost mine I went to Walmart and they allowed me to try several of the keys there. Eventually one worked. Took about 15 minutes.
