Refresh my memory on spacers
Discussion in 'Suspension' started by mikesfreetime, Feb 3, 2015.
  1. Feb 3, 2015 at 4:21 AM
    mikesfreetime
    mikesfreetime [OP] Member
    Virginia
    NA
    On my 2001 D-Cab several years ago I used a spacer lift that did not require a spring compressor. If I remember right it sat on top. I have checked Toytec, Revtec, and Readybuild and none of them are that way. Can someone refresh my memory please?
    I just bought a 04 D-Cab and want to go back with the same lift. I do nothing but street ride and actually barely due that since my commute is so short so its all about appearance to me. Thanks in advance. On the 01 I had a 2 inch body and the spacer running 33X1250 and want to have the same stance. Your help is appreciated.
  2. Feb 3, 2015 at 4:25 AM
    Large
    Large Red
    Same thing I would imagine. Buy the spacer, remove the coil assembly, place spacer on top of coil and re-assemble.
  3. Feb 3, 2015 at 4:34 AM
    jamtoz
    jamtoz frog
    James
    Quebec
    trd sport DCLB 4x4 2014
    Duratracs, SCS sr8's, debadged
  4. Feb 3, 2015 at 4:45 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Some require you to swap your top plate studs so that they are long enough to incorporate the new spacer.
  5. Feb 3, 2015 at 5:51 AM
    mikesfreetime
    Virginia
    NA
    I probably wasn't clear in what I was saying which is normal for me. Some of the kits require a spring compressor. There is one if I remember correctly that does not require a compressor. Which kit DOES NOT require a compressor?
  6. Feb 3, 2015 at 1:30 PM
    jamtoz
    jamtoz frog
    James
    Quebec
    The one i linked...
