Refueling Usually Results In Messy Overfill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cogito, Jan 14, 2023.
  1. Jan 14, 2023 at 11:13 AM
    Cogito
    Cogito [OP] Member
    2021 Toyota Tacoma Limited V6
    Forgive me if this topic has been discussed elsewhere, but I have a rather irritating issue with my 2021 Taco Limited. It seems that every time I fill up, the pump's auto-shutoff doesn't trigger until gas is already coming out from the filler and runs down the side of my fender. This happens at any gas station I go to, so it's unlikely it's a pump issue. I have been somewhat successful in shutting the gas off in time by listening to the pitch of the air coming out of the tube, but in a busy/loud location, this isn't practical. Is this a common issue and is there a solution if so?
    Thanks!
  2. Jan 14, 2023 at 11:15 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Are you under 36k miles? Take it to the dealership.
  3. Jan 14, 2023 at 11:30 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not common at all.
    RedWings44, 50Buck, 9th and 1 other person like this.
  4. Jan 14, 2023 at 11:58 AM
    ThreeBeers
    ThreeBeers Well-Known Member
    Ron
    2020TRDOR
    Not normal, there is a line that runs from the gas tank to the filler neck. This allows the tank to burp because the air in the tank is being displaced by the fuel. It is either kinked or clogged. But like a previous post said, take it to the dealership, it should be covered under warranty
  5. Jan 14, 2023 at 11:59 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    something's amiss. Take it in, and don't take "it's normal" for an answer.
    Till then... I would avoid topping off.
    And Welcome aboard!
  6. Jan 14, 2023 at 12:04 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Definitely not right unless it only happens at that single gas pump. It should click off when full. You never want to overfill your truck. Sounds like a trip back to the shop.
  7. Jan 14, 2023 at 12:08 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    another vote to take in for repairs, sorry.
    I know what a PITA this is, I had an old hoopty that did this.
    9th likes this.
  8. Jan 14, 2023 at 12:34 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Never had this problem with my '21 TRD.
    Since it happens to you at every gas station, the problem is either related to your truck OR to how you're positioning the nozzle in the filler tube.
  9. Jan 14, 2023 at 12:39 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    I would avoid topping off, can cause it not to start. it back flows gas into some canister gizmo.
    davidstacoma and zoo truck like this.
  10. Jan 14, 2023 at 1:33 PM
    Cogito
    Cogito [OP] Member
    Haven't even hit 9k on the odometer...
  11. Jan 14, 2023 at 1:34 PM
    Cogito
    Cogito [OP] Member
    Not topping off at all. By the time the auto-shutoff triggers, it's too late.
    davidstacoma likes this.
  12. Jan 14, 2023 at 1:35 PM
    Cogito
    Cogito [OP] Member
    I've been pumping gas for nearly 40 years and I have never seen anything like this.
  13. Jan 14, 2023 at 1:37 PM
    Cogito
    Cogito [OP] Member
    Thanks for the welcome!
  14. Jan 14, 2023 at 1:48 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Take it to Toyota. Until then, don’t use the auto stop capability of the pumps. Manually fill to a conservative amount of fuel.
    zoo truck and Chew like this.
  15. Jan 14, 2023 at 1:52 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Pretty sure this issue has been reported here a few times by others and required some sort of repair.
    CrispyTacoLover likes this.
  16. Jan 14, 2023 at 2:14 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    TnShooter and davidstacoma like this.
  17. Jan 14, 2023 at 2:37 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO3s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Agree with everyone else, not normal. Get it to the dealer.
  18. Jan 14, 2023 at 2:38 PM
    Pentangler
    Pentangler 24 Aces
    2022 DCSB OR 4x4
    Previous Toys: 2021 DCLB OR 2017 DCSB SR5 2006 RAV4
    My vote is also to take it into the dealership. Absolutely not normal and possibly dangerous too.
  19. Jan 14, 2023 at 3:31 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    If you top it off to the point where its spilling out, you can end up getting some liquid fuel going where the vapors are supposed to go. This would be the charcoal canister. I would just bring that pup to the dealer. It's not common, just a pain in the ass to have to go back to the dealer.
  20. Jan 14, 2023 at 7:09 PM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    Bring in for warranty work. Also tell them to inspect the Evap canister as overfilling the tank will eventually damage the canister. Push for that replacement if possible.
    Barsoom likes this.
