Refuling problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by merkman, Sep 10, 2012.
  1. Sep 10, 2012 at 5:05 AM
    merkman
    merkman [OP] Well-Known Member
    Etna, NH
    2012 green
    Well 1600 miles on the new 12. Fueled it up a few times and it took the fuel no problems, normal. Last refueling, the pump kept bumping off. Had to trickle it in. I think someone tried to syphon my fuel while parked in sketchy part of town for 2 nights. Gas door was ajar and cap loose.
    Having had my 95 yota's tank out in the past, I know there is a little springed gate at the top of the tank. I assume this got bunged up and isn't functioning properly, in the failed syphoning.
    Anyone have a Tacoma tank out of their trucks? Am I describing this right? Can I access this from the top of the tank w/o dropping it? There might be enuf room? I suspect it is just bent.
    Or take it to the dealer under warranty? Would it be honored as a warranty event?Thanks
  2. Sep 10, 2012 at 6:47 AM
    BamaToy1997
    Bill
    Navarre, FL
    If they found evidence of tampering (attempted siphoning) then they are not required to repair this under warranty. That being said, if you brought it to them stating you are having a refueling issue, they may look at it as a factory failure if nothing is mentioned. While this is immoral, it will possibly get your truck fixed under warranty. The other option is to file an insurance claim, which can affect your rates, and involve a deductible. You can of course see if you can find the problem and fix it yourself. The device on the tank where the fuel enters, while commonly called and anti-siphoning device, is actually called a rollover device, and is designed to prevent fuel from leaking out the filler neck in the event of a rollover. It appears that something is messed up there, causing fuel to back up and trigger the pumping stations stop control. The fact that you can trickle fuel in means that it is not totally blocked. Another thing could be that whatever they stuck in the neck got broken off, and is blocking the neck partially. If you are careful, you can try to remove the filler neck yourself. As I have yet to have to remove a fuel tank from a 2010 or later Tacoma, I am not sure how easily you can get to the clamp at the tank to remove it.
  3. Sep 10, 2012 at 6:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    And... time for a locking gas cap.
  4. Sep 10, 2012 at 7:08 AM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    Id make sure someone didn't stick something in there :cool:........:eek:
  5. Sep 10, 2012 at 8:29 AM
    shemp
    shemp Well-Known Member
    A lot of gas stations have maladjusted pump handles. Before you conclude that there's something wrong with your truck, try a different gas station.
  6. Sep 10, 2012 at 4:46 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    X3 on what Shemp said. I had it happen before on a previous vehicle, went to another pump and it went in fine.
  7. Sep 10, 2012 at 4:49 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  8. Sep 10, 2012 at 6:08 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    yea. theres a shell in my area that wont pump by itself on this truck. you have, however, brought me to wonder where MY little flapper-door thing went. i havent noticed it and thought maybe i was crazy for thinking one was there in the first place. . . . . . . . . . . . . crap
  9. Sep 10, 2012 at 6:23 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Here is what my 2012 F hole looks like.
    No flapper.
  10. Sep 10, 2012 at 7:01 PM
    Ragin Devildoc
    Ragin Devildoc MOLON LABE
    Doc
    Grunt Life
    12 Prerunner DCSB SR5
    16x8.5 level 8 guardian w/ hankook dynapro atm rf10, aFe pro dry s, flowmaster dbx exhaust, debadged, 2nd air filter removal
    Same here....no flapper
  11. Sep 10, 2012 at 7:19 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Hey me too!! Dahell??!??
  12. Sep 10, 2012 at 7:43 PM
    babytruck
    NorCal
    Huh. Just looked at my other car, doesn't have one either.
  13. Sep 10, 2012 at 7:43 PM
    babytruck
    NorCal
    Dahell??!??
  14. Sep 10, 2012 at 7:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Op is referring to the anti-tamper device that is down near the top of the tank.
    Not sure if it's in the hose or the tank cap itself, but not all vehicles have the flapper door at the top.
  15. Sep 10, 2012 at 8:52 PM
    92dlxman
    Kevin
    Visalia, CA
    ok thank you Rich for the clarification. i feel responsible for some confusion about f-hole flappers and such. oh god
  16. Sep 10, 2012 at 9:24 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Don't go messing with the F Hole Flapper!
  17. Sep 10, 2012 at 10:03 PM
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
  18. Sep 10, 2012 at 10:15 PM
    aportis72
    aportis72 Well-Known Member
    Austin
    Supercharger
    I have that gas cap for my 2012 from TRD parts4u and I threw a CEL so took it off :(
  19. Sep 10, 2012 at 10:40 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ROFLMAO at this discussion about F holes
  20. Sep 10, 2012 at 10:45 PM
    MikeCB600F
    Plainfield, IL.
    I have not had a CEL yet.
    Also keeps those from pouring in "unapproved" fuel additives.
