Refurbished Engine Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by jessejsalmon, Feb 13, 2024.
  1. Feb 13, 2024 at 10:52 AM
    jessejsalmon
    jessejsalmon [OP] Active Member
    Greetings,
    Not a mechanic. Just had a refurb 2.7 put in my 2000 Tacoma. Been in for only a few days. Mostly runs good, but seems to have more vibration and is maybe louder in general than original engine. Will the engine mellow out and become smoother with time?
    Much thanks.
  2. Feb 13, 2024 at 9:10 PM
    Glamisman
    Glamisman Well-Known Member
    Possibility that the motor mounts are bad and/or they just bolted them down. I like to leave them just a little loose for the first 5 minutes of so and let the motor and mounts “settle” in if that makes any sense.
  3. Feb 14, 2024 at 12:31 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Knowing what mechanics are charging these days, I would take this question to whoever put it in and keep asking until you get an answer you're happy with. I'd expect things to sound and act a little different, but more vibration is definitely something to look at. It could be anything from a component causing it to run poorly to something out of balance in the rebuild. Does the vibration occur when stopped or only when it's moving?
    Louder . . . not as much of a concern, or it could be something in the exhaust system has changed.
    I really don't expect time to fix anything, I've rebuilt a couple engines in my life and I always hear a little difference on first startup, then when it warms up, that's how it runs/sounds from then on.
    If you're not getting the answers you want, throw down a little more cash at another mechanic for a second opinion.
