Reg. Cab bench seat -> bucket seats
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hannabana, Oct 17, 2020.
  1. Oct 17, 2020 at 3:31 PM
    hannabana
    hannabana [OP] New Member
    2012 Toyota Tacoma
    Hello earthlings! First post here so bare with me. I just inherited a 2012 Tacoma from my pops. I has a regular cab with the classic bench seat. I was hoping to install buckets seats as the bench seats aren't ideal for my passengers with long legs. I know I will have to install two new brackets, as the bench seat only sits on two brackets. I'm hesitant to do this as I would have to drill through the floor of the cab. Any tips? Much appreciated!
  2. Oct 17, 2020 at 3:37 PM
    Tyler7544
    Tyler7544 Well-Known Member
    L
    The most unique and special Tacoma
    Just the first thought that surfaced in my mind, you could make a frame that uses the old seat mounts, basicly just a long rectangle that takes the place of the bench seat frame. Then fab mounts that bolt the new bucket seats to that. Its not the most elegant option, but it allows you to get away without drilling new holes.
    You could also make two individual mounts for each seat, but you will have to find a way of strengthening the sheet metal. Maybe welding 1/8 or 3/16 plates to the surface, and a nut on the back side so you do not need someone underneath the truck holding a wrench when you tighten the seat bolts.
    One thing to keep in mind is making absolutely certain that the seats won't move in a wreck.
  3. Oct 17, 2020 at 5:49 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    :wave: Yup, like these guys have said before me, any bucket seat from '05 to '20 will bolt in your truck. The big issue you will run into is the airbags, which I am not sure how to work around, since I didn't have to mess with them when I installed the 3rd gen seats in my truck.
  4. Oct 17, 2020 at 7:43 PM
    whiteknight4x4
    whiteknight4x4 Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    That really does look good but those 3rd gen seats hurt my lower back when I drive for more than an hour. I drove a turd gen for 3 months during my frame replacement and no matter how I adjusted the lumbar, it never seemed to help.
    Guess I'll have to make my 2nd gen last forever...
    whatstcp[QUOTED] likes this.
  5. Jan 10, 2021 at 10:22 AM
    dadams5302
    dadams5302 Member
    Dillon
    2009 Tacoma 4x4 Reg Cab
    I started a discussion on this a few minutes ago. From what I have dug up on Reg Cab Nation on Facebook and forums is that the holes already exist. The hardest part (after finding the seats and console) is the airbag harness issue for 09+. If it is plug and play great but not much info on it
    Daves300 likes this.
