Reg cab Cap on an extended cab truck?
Discussion in '1st Gen. Tacomas (1995-2004)' started by krlang, Nov 30, 2008.
  1. Nov 30, 2008 at 2:06 PM
    krlang
    krlang [OP] NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    Anybody got a pic of an extended cab topper on a reg cab truck?
  2. Nov 30, 2008 at 2:13 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Should work if the bed sizes are the same, otherwise might look in the redneck mods section ;):D
  3. Dec 1, 2008 at 2:15 AM
    krlang
    It is definitely different, I believe it is an inch different in height too.
    I have seen pictures on the internet, but I cannot find any now.
    I have found one on CL and they are telling me that they are the same.
    They dont have any pictures either.
    The angle of the cab is different and the ext cab cap almost hits the top of the window.
    I guess I will have to drive out there and fit it.
    K.L.
  4. Dec 1, 2008 at 10:27 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The rear wall of the Regular Cab is 'vertical' (straight up), while the XtraCab rear wall is slanted forward.
    Some topper manufacturers slant the front wall of their canopies / shells to match the XtraCab lines. Such 'slanted' XtraCab shells may hit the rear cab wall if fitted onto a Regular Cab. In any case, the lines of the rear cab wall and front shell wall won't match.
    If you put a Regular Cab top onto an XtraCab, you might be left with a very noticeable gap between the forward-slanting cab and the straight-up canopy.
