reg cab rear speakers
Discussion in 'Audio & Video' started by danteisme, Aug 21, 2009.
  1. Aug 21, 2009 at 9:30 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i came across this truck while browsing cardomain. whats everyone think of this setup? without taking my side plastic panels out, are they strong enough to hold up a speaker or do you think it was reinforced behind it. i i'm thinking of putting in a 6.5 speaker in this location. and since its a free air speaker, i'm not worried about making some enclosure for it. also this way it won't be muffled as much as the diy in this forum, the speakers face towards each other rather than into the back of the seats.
    so whats you're guys' opinions of this setup?
  2. Aug 21, 2009 at 9:37 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The speakers are still going to be substantially muffled in that tight location behind the seats.
    I don't see how it's going to be worth it ...
  3. Aug 21, 2009 at 9:45 AM
    danteisme
    South Western PA
    only other idea i had so they wouldnt be muffled was to get a couple 6x9 boxes facing up, and place them on that lip that the jack and stuff rest on.
  4. Aug 21, 2009 at 10:27 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    You'll get a lot more noticeable improvement and better sound imaging by upgrading the speakers up front. If you still think you absolutely need more speakers you'd get more benefit out of adding them in the kick panels.
  5. Aug 21, 2009 at 10:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    These are what I used in my reg cab.
    I separated the front of them from the back. Attached the backs of the speakers to the back of the cab with 2 self tapping screws, then glued the fronts of the speakers back on. They souned pretty good, and did not hinder the opperation or range of movement of the front seats.
  6. Aug 21, 2009 at 10:41 AM
    TIM GAINOUS
    TIM GAINOUS Well-Known Member
    tallahassee fl
    o7 base desert sand
    tints,venvisors,low pro toolbox, readylift sst ,afe pro dry,dynomax muffler,sec air filter removed. jvc aresenal, with rear jvc 6x9's front blaupunkts.
    HERES MINE[​IMG]
  7. Aug 21, 2009 at 10:46 AM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    eh... its an ok set up. i got the access cab nd therefore i culd sit ppl in the back seats near the speakers. in a reg cab i just don't see the pt if ppl aren't gonna be sittin bak there
  8. Aug 21, 2009 at 2:11 PM
    TIM GAINOUS
    tallahassee fl
    o7 base desert sand
    twice the sound. second gen std cabs are faded all the way to the front speakers. put the FADE CONROL in the center and you have 4 speakers instead of two, make a huge difference.
