Reg. Oil to synthetic?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pnicholas1019, Dec 1, 2011.
  1. Dec 1, 2011 at 7:36 PM
    Pnicholas1019
    Pnicholas1019 [OP] Well-Known Member
    Parker
    surprise
    '92 toyota tacoma
    6" lift, front bumper, Oil cooler, HID lights, toyo m/t 33's.
    I have been asking around and i keep hearing different stories so im turning to my boys at TW to get to the bottom of this. OK, Im running some 5W30 in my 92' yota. I have heard alot of stories that it will cause my truck to leak if i switch to synthetic. She doesnt leak or burn now so would it be a good idea to switch to synthetic? I just hit 220,000. :confused:
  2. Dec 1, 2011 at 7:38 PM
    hulkit
    hulkit Well-Known Member
    sacramento ca
    2000 tacoma 2.4l automatic
    300k switched to synth @ 296678 no problems 5w30
  3. Dec 1, 2011 at 7:39 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    My understanding is switching to synthetic won't suddenly cause an oil leak. What it can do is clean out any built up sludge in an already existing leak, causing it to leak once again. I'm also contemplating switching but I don't know if it is worth it for the increase in price of oil. I'm at 55,000 miles.
  4. Dec 1, 2011 at 7:45 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    This ^^.
    Do it! I switched to Amsoil at ~55K miles (about 5K miles ago) and could not be happier. :thumbsup:
  5. Dec 3, 2011 at 5:59 AM
    Pnicholas1019
    Parker
    surprise
    '92 toyota tacoma
    Thanks guys. I have 1k left and im swithchin over it will be best for the truck!
  6. Dec 3, 2011 at 6:19 AM
    CaliforniaKid
    CaliforniaKid Well-Known Member
    Jim
    Central California
    2010 Tacoma 4x4 Dbl Cab TRD OR
    Under Cover Bed Cover
    I have always been told when going from dino to synthetic, especially when a vehicle has a few miles on it , to put 1 quart of synthetic in with the dino for one oil change and then go full syn the next. Theory being full syn will, as previously mentioned, clean out sludge etc. and you don't want that breaking loose with a full syn change and plugging oil gallerys resulting in a fried crank and bearings. The 1 quart will start slowing disolving the deposits but not just break loose chunks like a full change.
  7. Dec 3, 2011 at 3:48 PM
    Pnicholas1019
    Parker
    surprise
    '92 toyota tacoma
    Will the oils seperate tho? So 4qts of dino then 1qt of syn?
  8. Dec 3, 2011 at 3:58 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If I were you I'd stick with dino. Your truck has been running on it for 220,000 miles and seems to like it...why mess with a good thing. I know some say you can make the switch at high mileage but at 220,000?? :eek: I wouldn't take the chance.
  9. Dec 3, 2011 at 5:21 PM
    CaliforniaKid
    Jim
    Central California
    Yes dino and synthetics mix perfectly and in fact the 1 quart of synthetic will fortify the dino oil. The 1 quart of synthetic before a full change over used to be preached by AMSOIL when they first started selling synthetics. But I do tend to agree with OffroadToy. To have done so well on dino for 220,000 miles why change to a much more expensive oil. Are you doing it to treat your baby or are you hoping for better gas mileage? I run Mobil 1 in my Tacoma and started running synthetic at the first oil change. Full synthetic at 5000 miles in my wifes Escape. But I have a Jeep Wrangler, 2003 now with about 60000 miles I bought used a few years ago and since I did not know what it had in it, I went with Valvoline Durablend 10W30 which is a blend of Dino and synthetic. I change the oil in it about every 3500 so hate to run full synthetic and change it that often. .
  10. Dec 3, 2011 at 7:17 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    2013 DCSB TRD OR
    OME 885’s w/NitroCharger’s 3rd Gen Leaf Pack w/Icon Progressive AAL 265/70/17 Falken Wildpeak’s 17x9 Raceline Defender Wheels
    Stick with what you've been using. Why change it? Your truck was designed for conventional oil.
  11. Dec 4, 2011 at 7:55 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I think this is the best thing....do nothing....think about the legendary history of all the old yota trucks with high miles...this was all acheived before ther even was such a thing as synthetic oil!
  12. Dec 4, 2011 at 8:03 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Gonna throw my $.02 in and agree with not making the switch. Why add a variable? Sounds like your truck is running great!
    The owner's manual for my '12 with V6 actually calls for dino/petroleum-based oil, whereas my 2010 Prerunner 4-cyl called for synth. I wonder why?
  13. Dec 4, 2011 at 8:05 PM
    OffroadToy
    Yep...when I sold my 88 4runner it had around 300,00 miles useing nothing but dino every 3,000. That engine still ran like the day I drove it off the lot.
  14. Dec 5, 2011 at 4:17 AM
    crainholio
    crainholio Well-Known Member
    Derp-o-rama post.
    History shows that synthetic oil came about as early as World War II.
  15. Dec 5, 2011 at 8:10 AM
    Mexicant
    Mexicant Well-Known Member
    B
    Crawlerado
    Braap
    I've switched over many of my vehicles in the past to synthetic. Never had a leak from any of them afterward and they almost all were switched at over 150k or way more miles.
  16. Dec 5, 2011 at 8:13 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    So we all agree, YES you CAN switch, but at that kind of mileage WHY would you WANT to?? It's the old "If it ain't broke, don't fix it" rule! :D
  17. Dec 5, 2011 at 3:12 PM
    crainholio
    Good point and perfectly valid, but there are situations that might warrant the change.
    I had a job where I put over 120 miles per day on my truck, running synth enabled me to run 9000-10000 miles between changes so it made sense. Regular oil would have required changing every other month.
    Sub-freezing conditions also make for better engine longevity with synthetic in 0W-xx viscosity.
    Just a data point for consideration.
  18. Dec 15, 2011 at 11:09 PM
    Pnicholas1019
    Parker
    surprise
    '92 toyota tacoma
    Alright so ive concluded to sticking wwith the dino solution, And yes it was to try and treat my truck with some more love since she is gettin up there in miles! thanks guys!
  19. Dec 16, 2011 at 3:54 PM
    azvikefan
    azvikefan Active Member
    Rochester, MN
    2016 TRD Sport 4x4
    Not exactly ontario. Mobil 1 has been around at least since the mid 1970's.
    I ran it in my new 1977 Suzuki GS750 with no problems at all. Air cooled engine and living in the AZ desert and Cali's high desert.
  20. Dec 16, 2011 at 3:55 PM
    JFKLives
    JFKLives Byte Me
    San Jose, CA
    2015 4x4 TRD Sport Extra Value W/JBL
    FJ Team Trail Red on Black Wheels P265/75R16 BF Goodrich Tire, color match front emblum, debadged and Fold-A-Cover G4 Elite
