reg or premium
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elitepbk, Aug 26, 2010.
  1. Aug 26, 2010 at 5:12 PM
    elitepbk
    elitepbk [OP] Member
    long island
    09 sr5 PreRunner
    This message is coming via blackberry, just pulled out the the shell station after i was filling my truck with regular, someone else in a tacoma pulled up and told me i was suppose to put premium in there, is that true?
  2. Aug 26, 2010 at 5:16 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    not unless you have a supercharger. all the manuals spec the taco's on regular and older 2nd gen manuals stated that you could get minor performance gains running premium
  3. Aug 26, 2010 at 5:17 PM
    YeahBoyyy
    YeahBoyyy I <3 Taco's
    Alabama
    2010, Sport, 4 door, Mag Grey
    Pioneer AVH-P3200BT head unit, Two 10" Rockford Fosgate p3 subs, Westin chrome bull bar, Westin chrome tube steps
    It probably says in your little booklet.. But I always put in premium.
  4. Aug 26, 2010 at 5:30 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    I always put Premium...
  5. Aug 26, 2010 at 5:36 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
  6. Aug 26, 2010 at 5:37 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    2010 4 X 2 Regular Cab
    Chrome exhaust tip
    I have the 2.7 four cylinder so I always use regular.
  7. Aug 26, 2010 at 5:38 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I split the difference and usually put in 89
  8. Aug 26, 2010 at 5:39 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I run 89 and it does great, 93 for anything that puts stress on the truck such as towing, hauling, etc.
  9. Aug 26, 2010 at 5:40 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    91 or 93 only. It's worth the extra $0.20.
  10. Aug 26, 2010 at 5:40 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Manual says regular...if the engine isn't tuned for premium, why waste the money? The computer will just retard the timing and/or adjust the air/fuel ratio effectively undoing any benefit you'd expect from premium. The only benefit I could think of is a cleaner burn and less knocking.
  11. Aug 26, 2010 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No...The manuals say "Best performance is achieved useing 91 oct. fuel".
  12. Aug 26, 2010 at 5:46 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    I use regular and have had no issues in daily driving. If I were to tow something heavy I would consider putting in a higher octane.
  13. Aug 26, 2010 at 5:50 PM
    JB3CK24
    JB3CK24 Return to the 36 Chambers
    Jeff
    SD, CA
    2001 4x4 TRD, 2003 BMW 330i ZHP
    87.. 91 is not needed. It's not a high performance engine..
  14. Aug 26, 2010 at 5:53 PM
    Incognito
    VA
    X2
  15. Aug 26, 2010 at 5:56 PM
    Incognito
    VA
    I'll check tomorrow afternoon, but I could have sworn it said that...
  16. Aug 26, 2010 at 5:57 PM
    jhodge83
    SC
    17 XLT Sport
    this is from an 07 manual....
    OCTANE RATING
    Select Octane Rating 87 (Research Octane
    Number 91) or higher.​
    Use of unleaded gasoline with an Octane
    Rating lower than 87 may result in engine
    knocking. Persistent knocking can lead to
    engine damage.​
    If your engine knocks...​
    If you detect heavy knocking even when
    using the recommended fuel, or if you
    hear steady knocking while holding a
    steady speed on level roads, consult your
    Toyota dealer.
    However, occasionally, you may notice
    light knocking for a short time while accelerating
    or driving up hills. This is normal​
    and there is no need for concern.
  17. Aug 26, 2010 at 5:58 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    Aren't all engines required by law to run on 87 octane? Not trying to stir the pot but just looking for confirmation.
  18. Aug 26, 2010 at 6:02 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    89 here
  19. Aug 26, 2010 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My manual states exactly what I posted above.
  20. Aug 26, 2010 at 6:05 PM
    jhodge83
    SC
    17 XLT Sport
    here is from an 05 manual....it stated it once upon a time, but not in a while...
    2TR- FE engine—
    Unleaded gasoline, Octane Rating 87
    (Research Octane Number 91) or
    higher
    1GR- FE engine—
    (Research Octane Number91) or higher.
    For improved vehicle performance,
    the use of premium unleaded gasoline
    with an Octane Rating of 91 (Research
    Octane Number 96) or higher
    is recommended.
    Fuel tank capacity, L (gal., Imp. gal.):
    80 (21.1, 17.6)​
