Regarding Bilstein 5100/AAL
Discussion in 'Suspension' started by Phrosty, Jan 12, 2013.
  1. Jan 12, 2013 at 12:24 AM
    Phrosty
    Phrosty [OP] Active Member
    Taylor
    Florida
    10 PreRunner SR5 DC
    Before I order this, I'd like to check to make sure that what I am ordering is what I need for a 2.5 inch lift front and 1.5 AAL rear if it will make the truck completely level, I have a 10' double cab. From what I've read, with this set-up, I can run 285/75/16 on it with some trimming.. I plan on getting Hankook Dynapro ATM's and I'd be running stock wheels for the time being..would that work with trimming? Thanks guys, and below is what I *think* will be needed to achieve a solid level lift for the truck to fit 33in tires, let me know if I'm right or wrong and anything else I should know.
  2. Jan 12, 2013 at 9:35 AM
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    ^^^This^^^
    If you set the 5100 billies to 2.5 with stock coils your truck will ride like shit. If you put Eibach coils on the billies set @ .85 you will achieve 2.5" and a great ride. As for the rear AAL, you can do the 1.5" TSB AAL, although this is a better option http://downsouthmotorsports.com/i-4764011-icon-vehicle-dynamics-toyota-tacoma-05-up-rear-add-a-leaf-kit.html (And yes, this will level your truck completely)
    As for the tires, you may have to do a cab mount chop. unless you're an extreme off-roader, than they won't rub that much if at all after removing mud flaps, and some trimming.
  3. Jan 12, 2013 at 10:12 AM
    Phrosty
    Taylor
    Florida
    10 PreRunner SR5 DC
    I don't extreme off-road, hoping trimming and just removing the mud flaps will be enough.
    Do I have to have the TSB done to get the 1.5" AAL? I am unsure whether or not I have it..
    Is it really that bad of a ride? I'd like to save $300 if I can..if the difference is that huge, I'd bite the bullet and buy them with the springs, though.
  4. Jan 12, 2013 at 10:16 AM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Honestly I don't think it's that bad when the billies are set on 2.5
    I've got a reg can so weight may be a huge contributing factor. It's stiff but i don't feel like I'm getting beat up.
  5. Jan 12, 2013 at 10:18 AM
    acdronin
    acdronin Well-Known Member
    The stock UCA's at that height may not allow the front to be properly aligned. There is much here about alignment and how high you can go. The common rule of thumb is no higher than 1.85 on the front billies BUT, i have seen a DBCB that was 2.5 or 3.0 on stock UCA's and the owner said he didn't have a problem gettin the front to align.
  6. Jan 12, 2013 at 10:22 AM
    Blueitrgsr
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    I did shock at 2.5 and 2in AAl and had no alignment issues.
  7. Jan 12, 2013 at 10:24 AM
    acdronin
    I have billies set at 1.85 on stock coils and i would say the ride is stiffer than i would like.
  8. Jan 12, 2013 at 10:24 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I have 5100's set at 2.25 with stock coils & stock UCA's and The ride is great and it is aligned fine.
  9. Jan 12, 2013 at 1:08 PM
    Phrosty
    Taylor
    Florida
    10 PreRunner SR5 DC
    Thanks guys with stock coils for chiming in. Sounds like ill be fine with the 5100's raised to 2.5...I don't mind a stiffer ride. I use the truck for a DD, dirt roads, and pulling my bass boat. No extreme off-roading.
  10. Jan 15, 2013 at 5:59 PM
    jmast
    jmast Is it June yet
    O.I.C.
    2011 DCLB TRD SPORT
    Taz mudflaps
    bass boat?
    florida?
    Those words put together make my thumb tingle
  11. Jan 16, 2013 at 11:11 AM
    Phrosty
    Taylor
    Florida
    10 PreRunner SR5 DC
    Hahaha we just bought a new Ranger Z119..lot of fun man.
  12. Jan 17, 2013 at 7:58 AM
    tsuhrke
    tsuhrke New Member
    Sonoma County, CA
    11 TRD OR
    I measured the front and rear of my 2011 TRD Off Road (stock all around) and the difference in height was 3" on both. I ordered the 5100's, planning to set them at 2.5, and a 1.5" add a leaf from Toytec. I'm assuming, unless I'm missing something, that my truck would not be level. I ordered the 5100's and the add-a-leaf with the plan of a level truck. Anyone had a similar situation?
