Regear 15miles or 15 minutes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chairmanmeow66, Mar 24, 2023.
  1. Mar 24, 2023 at 5:17 PM
    Chairmanmeow66
    Chairmanmeow66 [OP] Well-Known Member
    2020 Tacoma TRD off road
    Hey guys just got regear done and am a bit confused on break in. So some sources say 15 to 20 minutes and some say 15 to 20 minutes which is it living in Houston means 15 minutes only gets you about 5 miles or so
  2. Mar 24, 2023 at 5:24 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Contact who did the regear and go by that to support their warranty.
    Usually it’s 15-20 miles stop let cool and continue that for 100 miles. After 100 miles drive conservatively till 500 then change fluid.
    Wait til after the first 500 to tow. First tow drive 15 miles then cool repeat for for 45 miles for a total of 3 times.
  3. Mar 24, 2023 at 5:24 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It’s not going to matter much either way, I’d shoot for 10 miles or so. The main thing is to heat up and cool off the gears.
    Chew likes this.
  4. Mar 24, 2023 at 7:03 PM
    Chairmanmeow66
    Very well thanks for the input gentleman!
  5. Mar 24, 2023 at 10:31 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    The factory gears are manufactured differently than aftermarket so don’t need the same kind of break in. OEM gears are cut under immense pressure, whereas aftermarket are not, hence requiring you to do the work-hardening of the gear face.
    71tattooguy likes this.
