Regear 2nd gen - 4.88 vs 5.29 gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bbaggett, Oct 28, 2019.
  1. Oct 28, 2019 at 10:11 AM
    bbaggett
    bbaggett [OP] Well-Known Member
    Trophy Club, TX
    2013 Tacoma Limited DCSB 4x4
    6" Rough Country lift, 295/65R18 Duratracs
    I have a 2013 Tacoma Limited 4x4 DCSB v6 and have 295/65R18's which equate to 33.1" tires, which has a 6" lift. I also will be pulling a relatively small 3,200 lb empty travel (4k lb GVWR) trailer/camper about 8-12 times a year. My understanding is 4.88 is better for daily driving and 5.29 help in mountains/over 70 mph or what are the advantages/disadvantages? I've seen people saying 5.29 for sure for 3rd gen since it has a 6th gear but not sure what is better for 2nd gen.
    4.88 or 5.29? Thanks for the advice.
    george2pak likes this.
  2. Oct 28, 2019 at 11:18 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Automatic or manual tranny?
    bbaggett[OP] and whatstcp like this.
  3. Oct 28, 2019 at 11:28 AM
    bbaggett
    Trophy Club, TX
    Automatic
  4. Oct 28, 2019 at 11:32 AM
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    4.88
    Maybe even 4.56 for that tire size
  5. Oct 28, 2019 at 11:34 AM
    gotoman1969
    Since you shouldnt tow in 5th gear, I’d go 456 or 488. Imo it think 529s are way to low for the automatic. I generic rule of thumb is you will get approximately 250-300 rpm for every gear size you go up +\-. I believe there is chart on here somewhere that’s give the rpm #s for gear size
    bbaggett[OP] likes this.
  6. Oct 29, 2019 at 10:01 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    i have 4:56 gears and i run 35" super swamper tires. I Would 100% recommend that you go with 4:56 gears for 33's. if you put 4:88 gears while running 33" tires, your truck will most likely be screaming at 65 mph. For your trucks sake, please reconsider.
  7. Oct 29, 2019 at 10:29 AM
    bbaggett
    Trophy Club, TX
    Honestly, after I read more and more about things, I think 4.56 is where I will go. I started out reading about 5.29 and 4.88 and think that many of those debates are for 3rd gen, not 2nd gen (which I have). I have seen it be about 4.56 being the most "factory-like" for gas mileage + highway and 4.88 being for performance + screaming on the highway with higher RPMs. I want it to feel stock, I think 4.56 is where I should go. Thanks for the comment about asking to reconsider!
  8. Oct 29, 2019 at 10:53 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    It depends on how high rpm. you are comfortable running with. The rpm chart at "West coast Differential calculator" My 2013 W/ oem 4.11 gears, @ 60 mph, it runs 1988 rpm, with 4.56 it goes up 218 rpm, with 4.88 it's up 373 rpm. & with 5.29 gears it's up 571 rpm. I'm thinking I want to go up appx. 400 rpm. so the 4.88 for me. The 5.29, I think, will be turning more rpm. than I would be comfortable with during daily driving.
  9. Oct 29, 2019 at 10:57 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    What gear ratio is your Taco now?
  10. Oct 29, 2019 at 11:03 AM
    bbaggett
    Trophy Club, TX
    I think factory is 3.73 for my 2nd gen v6 4.0L.
    MtnMan307 and AbunaiTaco like this.
  11. Oct 29, 2019 at 12:03 PM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Their calculator chart uses: Trans,= auto. w/OD, tire diameter,= 295/65/18 is 33.1", speed= 70 mph. chart indicates w/ 3.73 gears= 1855 rpm., w/ 4.11=2044 rpm, w/4.56=2268, w/ 4.88=2427, & w/ 5.29=2631. My trans is a 4/OD auto. If I shift from D to 3 @ appx 60 mph. the tach. goes up appx. 800 rpm. If your trans. is like mine, drive in 3 for a while, that will be roughly the same that you will have constantly if change to a 5.29. For me, that was too many rpm., I figured about half that, 400 rpm. should meet my needs.
    AbunaiTaco likes this.
  12. Oct 29, 2019 at 12:27 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    I put your #s in and with 3.73 and 33.1 inch tires towing in 4th (not D=5th) you will be at 2600rpm at 65 which is about perfect so why change anything. At 70 its at 2800 rpms. Did you recal speedo for your tire size already? Daily you want lowest rpms for mpg in 5th not screaming along but its your money as mpg will drop like a rock.
  13. Oct 29, 2019 at 12:44 PM
    gotoman1969
    You could also put 4.30s is and be right is nice spot for daily driving in 5th and good for towing in 4th.
    Biscuits likes this.
  14. Oct 29, 2019 at 12:53 PM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    This is what I'm looking at. But I'm also MT and looking at 35's. That puts me back at stock ratios with 35's. There is a great calculator that I used, but can't remember the links. Also, reach out to someone that has done it with similar specs and get their real world feedback. Preferably someone that travels the same types of roads, flat, mountains, etc..
    I'm thinking the auto's are geared differently and that 4.56 would be more than enough for the 33.
  15. Oct 29, 2019 at 12:58 PM
    gotoman1969
    I’m running 430s(4.0 auto)
    and like them a lot, but I agree if your towing and lots hills etc, 456 is the way to go. If your 6 speed manual I’d drop 488s in.
    AustinM2015 likes this.
  16. Oct 29, 2019 at 1:01 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I dont follow, I have the manual and with 33s I still wish 6th were taller.
  17. Oct 29, 2019 at 1:01 PM
    Armyhater458
    Clarion, PA
    2012 TX Pro
    Now you have confused me. I thought the 6 speed manuals were lower geared in the transmission. I originally was set on 4.56, but after checking with the calculator it showed 4.30 and 35's would put me back to stock gearing roughly (within 100 or so RPM) Please elaborate, even though a re-gear is a couple years off.
  18. Oct 29, 2019 at 1:04 PM
    Bannerman
    Johnson
    Charlotte, NC
    I'm also confused. See my comment above. 4th is OD and 5th and 6th are too close together for me. I wish 5th was the same and 6th was taller.
  19. Oct 29, 2019 at 1:12 PM
    gotoman1969
    Is your running 33s. Correct if I’m wrong the stock gear on the 2nd gen 6 speed manual is 410. If you went +2 on tires/wheel size. You should basically grab on gear size per tire size you went up. So I’d run 456 for 33s and 488s for 35s. Going that route will put you approx 200 rpm I’ve stock. Just my opinion. If you tow stuff , find the gear that takes you back to stock and go one over. It will give you a little higher rpm for when your towing but won’t kill you too bad when you not.
  20. Oct 29, 2019 at 1:14 PM
    Bannerman
    Johnson
    Charlotte, NC
    I dont think that's correct. I'm fairly certain we have the same ring as the auto. Final drive ratio is only different due to tranny gears.
