Regear 2nd gen - 4.88 vs 5.29 gears
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bbaggett, Oct 28, 2019.
  1. Aug 14, 2023 at 1:22 PM
    #241
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    It might help us help you if you share how you intend to use truck and what are your priorities. In high gear at about 70mph you will find about 200rpm difference from 4:56-4:88-5:29 if that helps.
  2. Aug 14, 2023 at 1:55 PM
    #242
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    coming from a 2nd gen so maybe fact check ... but I think 3rd gen has that 7 speed AUTO and the 5.29 works b/c the 2nd overdrive gear works well with it. The 2nd gen auto doesn't have that additional gear.
    You have the manual with 6 gears so you'd probably want to use the gear site to check your RPMs at various speeds. I am not sure if you'd end up the same as the auto 2nd gens or not but I'm sure someone knows.
  3. Aug 14, 2023 at 6:07 PM
    #243
    TacoTuesday1
    SD CA
    well it’s not a tube frame chassis on 40’s getting trailered to king of hammers
    I think 2nd gen 5AT 5th drops RPM low so people regear more
    Even more so for 3rd gen 6AT where 6th is an extreme overdrive, that coupled with a crappy TCM
    honestly in my opinion (may be wrong) I think most shops are using the shittiest calculator to make recommendations and quoting whatever their experience is on an auto 3rd gen which is apples to oranges because they are different trucks in terms of motor, gears/speeds, and ratios
    I used the Grimmspeed calculator to see how 4.88 looks better than 4.56
    And no store has told me about using grimmspeed which lists the exact RPMs, speeds, and specific trans
    I feel like their calculators are a Leapfrog from Toys R Us
    Have even seen such a low quality calculator on one of their websites. That had no differentiation on the specifics of the vehicle.
    And when I ask them about RA60F (the manual trans) they act confused like they don’t know what that means.
    Grimmspeed is probably the best calculator
    And it takes time to use
    Vs calling a shop they say “hold on” Toss the Magic 8 ball (or not at all) then say 5.29
    again I could be wrong maybe 5.29 is magical but simply having at least one drawback in that you can’t swap in a stronger axle if you need to later that matches ratio
    Because while other bigger axles do come available in 4.88, they do not in 5.29.
    I think it will be hard to complain about 4.88 if coming from 3.73.
  4. Aug 14, 2023 at 6:22 PM
    #244
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    I’ve had 4.88’s and 35’s with a RA60F. I broke 3 of the ECGS elocker set ups. That being said I swapped back in my sport rear axle with 3.73’s. Next time I regear I’m doing 4.56’s. It screamed at 3k @ 70 and would be around 5k around 80 in 6th down the freeway. On the highway, back roads and going over MT passes it was a freaking monster and could haul ass. If you ever plan on driving on the freeway do 4.56. It sucked going on road trips on the interstate doing 60 because at 3k it got 11.5 mpgs.
    Wackyhacky and 01 dhrracer like this.
  5. Aug 14, 2023 at 8:15 PM
    #245
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    You must be doing some hard wheeling..
  6. Aug 14, 2023 at 9:40 PM
    #246
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Two let loose on the Freeway and one doing about 15 mph in the snow. I do things with my truck, but wouldn’t consider it hard wheeling by any means. I’m the type of person that will drop into 4low and engage the locker to make something easy so I don’t break shit because I still have to drive it to work on Monday.
    TimberTiger and dk_crew like this.
  7. Aug 14, 2023 at 11:51 PM
    #247
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I was also 4.88 for AT and 4.56 for MT if you're going 35's. I have been running 4.56 on 315's and the S/C and its been a nice setup. 4.56 with 285's i thought was perfect. a tad higher RPM but it drove nice. Def took a hit with the tires before the S/C.
    That being said I went through 3 diffs or I am on my 4th one after regear and 2 ECGS swaps in 3-4 years.
    That being said I would def not do 5.29. I have buddies running 37's an they still run 4.56 or 4.88. I am swapping to a Fab'd Tundra rear in a couple of months ( You can get this in 5.29 if you really wanted to ) but they do not have it in 4.56 so will be going 4.88 and re-gearing the front again in 4.88.
    Deep down I want to go with 37's at some point so this adds to that option.
    dk_crew likes this.
  8. Aug 15, 2023 at 5:25 AM
    #248
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    Gotcha.. over looked you were a MT.. I’m the same way.. trucks gotta get me home and to work on Monday.
    Shadowhunter[QUOTED] likes this.
  9. Aug 15, 2023 at 10:13 AM
    #249
    TimberTiger
    TimberTiger Get Western! ... ig @tcave87
    Tanner
    Arlington, Wa
    2014 DCSB Trd off road , 2002 Ext Cab Trd
    2014 DCSB: nitro 4.30 gears, Eaton/Harrop front locker, Bilstein 6112's w/ 650#, Camburg ball joint UCA's, Marlin cam tab gussets, Wheelers superbumps, Deaver U402 stage 2 leaves, bilstein b110's, u bolt flip, Archive hammer hangers, ADV weld co hybrid sliders, ADV weld co bed rack or Leer 180 w/ windoors, full RCI skids, SCS stealth 6, 35x10.5 kenda RT, ATH fab HC rear bumper, US offroad stealth front winch bumper, Smittybuilt x20 10k winch, ARB simpson III rtt, plenty of dents and scratches Now Sold 2002 TRD ext cab: 06 TRD Tundra coils, tundra 5100s, wheelers HD 3 leaf AAL, rear 5100s, ARB front bumper, SkidRow front skid, Leer commercial cap with windoors, 285/75r16 Kelly Safari TSR
    4.30 gears on 35x10.5 with the 6 speed manual here, full armor, canopy, and a RTT. 4.30's have been great on the skinny 35's and you can get a rear diff from a 3rd gen 4runner and save a bunch of money.
    dk_crew likes this.
  10. Aug 15, 2023 at 4:49 PM
    #250
    cdex8357
    “Dex”
    H-Town
    2013 Taco OR
    I just got the 4.88 haven’t installed them. Got the front locker. Don’t think I’ll need it, but got it.
    I do a mix of both highway and city.
    don’t wanna have to replace a diff just for city driving and some occasional wheeling.
    dk_crew and nudavinci64 like this.
  11. Aug 15, 2023 at 5:59 PM
    #251
    TacoTuesday1
    SD CA
    well there you have it. Looks like there is no right answer.
    Gonna go 4.88 and see what happens. I trust ECGS and KFlos recommendations given he’s engineered and probably researched the fuck out of it.
    the fact that Grimmspeed caulculator shows RA60F made to 4.30 or 4.56 behaving close to stock (crap) means it should bump up to 4.88 for weight.
    I’m curious to how a 4runner diff is cheaper than a spare third for $50-150.
    It may save $250-$500+ on master install kit and gears
    but I’m guessing they’re 8” elocker only and not the stronger 8.4”
    this does make me wonder about swapping in a different third or whole axle.
    You can find used 3rd gen axles which are bigger.
    I don’t know if any factory thirds in 8.4” have better gears. Sequoia tundra T100 all likely crappy gears from factory.
    FJ is 4.30 rear but might only come in 8” elocker.
    I heard some 3rd gens have around 4.30 rear but such part used will likely be overpriced and impossible to find.
    so far have not found anywhere to confirm stock availability on a front torsen
  12. Aug 15, 2023 at 8:08 PM
    #252
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Always had a soft spot for 4.10's
    dirtnsmores likes this.
  13. Aug 15, 2023 at 10:18 PM
    #253
    TacoTuesday1
    SD CA
    I got a set if you need it
    Dacapster[QUOTED] likes this.
  14. Sep 7, 2023 at 10:37 AM
    #254
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Enjoy my 4.10 with 255/80/17s
  15. Nov 14, 2023 at 10:43 PM
    #255
    tbraumb11
    tbraumb11 Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    I have a v6 4.0 auto trans currently on 265's but going to 315 e rated 17's soon
    I have steel rear bumper, 4x innovations swing out steel hybrid front, aluminum full skids, tonneau, steel bed rack, standard rooftop tent prinsu roof rack, 6ft awning synthetic winch, rango shackles and hangers, road shower, 4 gallon gas and water, high lift and lots of other weight like compressor gussets and so on 3" lift with 1" body lift.
    I do a fair bit of highway driving to get to offroad and camp spots I load up with lots of camp gear 2 x 12 foot kayaks but other than adventures I don't drive that much since I work from home.
    Leaning towards 4.88 am I on track?
  16. Nov 15, 2023 at 3:28 AM
    #256
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I did the same switch. Just drove 1k miles from TX to CO for the winter and the 488s are good on the hwy and great off road. I don’t have all that weight but if I did I’d still go with this setup unless I was right next to the dirt with little to no hwy driving.
  17. Nov 15, 2023 at 7:47 AM
    #257
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you’re actually going to daily drive or highway drive, 488 is the way to go. If it’s not your daily and maybe short highway to your camp/off-road, I’d say fugit and do 5.29 gears. Only thing with 529 is that you’ll need to swap the front carrier assembly to a thin ring gear/390 and up gear carrier. Not a problem if you put in a locker, because you’re already replacing the carrier.
    Naveronski and dk_crew like this.
  18. Feb 22, 2024 at 12:50 PM
    #258
    Kjlawhon
    Kjlawhon New Member
    Kevin
    2013 White Tacoma 4x4
    11 inch lift on 37 Super Swampers stock 4Runner 17’s still have cv axles in 4.10 stock gears 9,000lb winch in aftermarket bumper
    My 2013 4x4 came with 4.10’s stock
  19. Feb 22, 2024 at 1:52 PM
    #259
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    cool
    dk_crew likes this.
  20. Feb 22, 2024 at 2:04 PM
    #260
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, it didn’t unless it is a 4banger then yes
