Regear for 32 inch tires 4x4 4 cylinder?
Discussion in '1st Gen. Tacomas (1995-2004)' started by AdventureNorth, Jul 6, 2016.
  1. Jul 6, 2016 at 2:10 PM
    AdventureNorth
    AdventureNorth [OP] Member
    Washington
    2000 tacoma 350k miles
    Wheels/tires
    My truck is a 4 cylinder. I'm wondering if I would need to regear if I wanted to upgrade to 32s since it's a smaller engine? I have aftermarket 31s off road tires right now with no lift but I'm planning on a 2.5 or 3 inch lift soon after boot camp and 31s look odd on a lifted rig imo. Input?
  2. Jul 6, 2016 at 3:26 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I would advise a regear but it's not mandatory. I'm 3.4 and supercharged and I feel very underpowered in 5th on 32" KM 2's.
    Heavily depends on your needs and driving habits. I like to drive fast and pretty much every time I hit the high way I punch it to 100 then cruise at 85, don't spend a ton of time crawling boulders. You might be fine maxing at 70 on the high way for the low range torque you'd have while wheeling.
    For me I feel 32" is too tall for stock gears. I'd stay at 31" or if you're set on bigger step it up to 33" and regear to 4.88's.
  3. Jul 6, 2016 at 6:52 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Clays response is good info there. I have run 32's with my 2.7, it still goes okay, needs some help on the hills at times. But ideally getting a lower ratio would be best to regain the lost power. Im kinda with clay though, since youre gettin a lift anyways just jump to 33's and go 4.88?(id prolly get 4.88 with 32's also, but i kinda prefer a lower geared rig myself) A lil trimmimg would be in order for 33's though, the pinch weld atleast. But depending on wheel BS that might be in order with 32's anyway.
  4. Jul 6, 2016 at 8:25 PM
    AdventureNorth
    Washington
    Wheels/tires
    Thanks for the response guys! I'm new to the regearing I'm not completely sure what the process involves. What gears are we referring too when people talk about regearing? All I know that a lift, new tires, and regearing is going to be a shit ton of money haha. It's too bad I need tires so soon I may have to put my old set of wagon wheels back on to save up.
  5. Jul 7, 2016 at 4:14 AM
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    A regear deals with the ring and pinion gears in your front and rear differentials. By changing the amount of teeth on them you can change your drive ratio.
    Gears are pretty pricey. If you can pull the differentials out of your axle housings (highly recommended) you're looking at ~ $500-700 for parts and labor per axle.
    I've never attempted the work myself so I can't help in that department but for just parts it's about ~$300.
  6. Jul 7, 2016 at 4:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    If you are doing the lift/tires to gain function because you have off road problems it will solve in your current state, proceed, and plan for a regear.
    If you are doing it for looks, that's an expensive proposition for a 350k mile vehicle. You'll be rapidly approaching the total value of the vehicle from an insurance carriers viewpoint.
  7. Jul 7, 2016 at 6:42 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    What does your door jam sticker say you currently have for gear? Some had 4:56's from the factory.
  8. Jul 7, 2016 at 1:28 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Like mentioned, try to figure out what gears you have stock first. Also is it auto or manual trans? I have 33"s on my 97 2.7 5spd with stock 4.10 gears and honestly it's not terrible, won't win any races, but it's drivable. It is a little to high geared for rock crawling type situations but using your head you can work around it. I'm happy with how it feels on the street and still pull 22-24mpgs daily driving, so I think if I had the money I'd skip the regear and just do a tacobox to give me the lower gearing I need when wheeling but not hurt my highway performance.
  9. Jul 7, 2016 at 6:33 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    since YOUR aready going from 31s your not really gona notice how much slower your truck is the 32s. 4 banger auto is gona be slow no matter what...
  10. Jul 7, 2016 at 7:02 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
  11. Jul 7, 2016 at 7:24 PM
    AdventureNorth
    Washington
    Wheels/tires
    Thanks for the advice you guys. My door jam sticker isnt on my truck. I'm going to have to look up the serial number. And yes I agree I don't think I want to put an extreme amount of money into my truck with this many miles. She's my first car and runs like a champ so I'm not complaining, but I do a lot of road tripping/highway miles as well as off road trails (no rock crawling) to get to campsites and such and I'll be moving to Alaska here shortly and will be doing a lot of back country exploring and snow driving so I'm kind of all over the place in terms of what I use my rig for. It is a manual 5 speed by the way, very good truck. I'll find out what my gears are real quick and get back to this.
  12. Jul 7, 2016 at 7:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    Use this method. http://www.how-to-build-hotrods.com/gear-ratio.html
    At the age, mileage, previous owners, etc. you don't really know if someone has already been in there, or the data you look up will be correct.
    If you use the method above, you'll know exactly what you have. Faster than digging for numbers.
  13. Jul 7, 2016 at 7:45 PM
    devinzz1
    devin
    2023 aclb trd or mt
    ^^^ if you do that method then spin the wheel 10times. Much more accurate. It can be hard to tell the difference between close ratios with just 1 turn.
