Regear for more MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaineTaco, Sep 20, 2009.
  1. Sep 20, 2009 at 5:52 PM
    MaineTaco
    MaineTaco [OP] The NUTS
    Bangor, Maine
    06 AC 4X4 4.0 6speed Base
    K&N drop in, Ride TSB, Tail gate TSB, Scan Gauge ll, Factory seat covers, Hella head lights
    Ok I think that this is a new one... I have a 2006 AC 4x4 4.0 V6 6 speed w/ 265/75/16 Genaral Grabber AT2. Now I know that the Auto's get better MPG's on the highway because they turn fewer RPM's. What if I could re gear to turn lets say 800 RPM less at 75MPH, would it be worth it in the long run "200,000 miles" to save some gas?
    Will
  2. Sep 20, 2009 at 5:53 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I would say no, only because it is a truck. You would get better returns getting a second set or rims with smaller, less agressive tires for street, then swam them out with your ats for offroading
  3. Sep 20, 2009 at 6:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You would use more fuel. It would put more load on the engine, and your economl would suffer.
    mojojojo78 and gnorv like this.
  4. Sep 20, 2009 at 6:14 PM
    MaineTaco
    Bangor, Maine
    How? The Auto's turn less RPM'S and get better MPG's
  5. Sep 20, 2009 at 6:18 PM
    DanGer
    you will lose a good amount of power is what chris is saying. Your engine will have to compensate for that by burning more fuel
    gnorv likes this.
  6. Sep 20, 2009 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    There is a narrow RPM window for economy. Too little of a gear, hurts mpg, and too much gear hurts it. If the lower the gearing, the better the mpg, all OD gears would be as low as possible. Generally, best economy is had around 2/3's of the way to the peak torque out put of the engine. Being as the 1GR has a peak around 3800 rpm, best economy gear would put the truck near 2000 rpm at 65 mph. Which is about what it is stock.
    bdbrown likes this.
  7. Sep 20, 2009 at 6:31 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    ^ This...
  8. Sep 21, 2009 at 4:21 AM
    MaineTaco
    Bangor, Maine
    Chris again you have upstaged yourself!!! You my friend, are a wealth knowledge.
    Will
    Alexely999 likes this.
  9. Sep 21, 2009 at 4:23 AM
    MaineTaco
    Bangor, Maine
    But wait would the same be true if you had a supercharger? I know a S/C and MPG don’t really go together but you can see my "what if".
    Will
  10. Sep 21, 2009 at 8:00 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Try 70 instead of 75. Saves a mpg or two, and no speeding tickets. Probably only hit those speeds on I-95 anyway, for typical two lane state/county hwy (65 and under) 6th about perfect to pull low 20's mpg.
  11. Sep 21, 2009 at 8:18 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You will never recoup the money you spend on a gear change in fuel savings. Rear end gear ratios do not effect highway gas mileage very much unless there is a big spread in ratios. Say you went from a 4.10 to a 3.73, you would hardly notice much diff in fuel economy. In fact, like Chris pointed out, you will have to compensate with more gas pedal in the city. JMO.
  12. Oct 6, 2009 at 2:50 PM
    b168
    b168 Well-Known Member
    South Bay, CA
    09 Tacoma DC TRD Off Road
    6" Pro Comp Lift 35" Xtreme A/T Pro Comp Tires 4.56 Gears
    :confused::confused::confused: I just had mine regeared... but it still feels like theres not much diff well infact there should be a diff esp when u press the gas from a full stop. I had mine regeared to 4.56"s???????
    My question is, is there a way to find out, aside from diamantling the whole diff, if what they installed was really a 4.56 and NOT a 4.10's.
    Please help Thanks!:confused::confused::confused:
  13. Oct 6, 2009 at 5:32 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    '20 Grey TRD Off-Road 6spd
    TC +2 LT, Kings, BAMF Armor, 35s, gears
    Maybe compare what your top speed is in 1st, 2nd, 3rd, etc gears with somebody else? Then maybe you can do some math somehow to figure it out idk...
  14. Oct 6, 2009 at 7:28 PM
    jay_shy
    jay_shy Active Member
    09 silver access cab TRD sport
    jack up both rear wheels and rotate rear tire one full revolution and count how many times the drive shaft turns. Would give you a pretty good idea.
  15. Oct 6, 2009 at 7:48 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    This will get you close:get a gps and go 60 mph. that is 63360 inches per minute
    265 (tread width appx) divided by 25.4 is the inch width.=10.43"
    10.43x.75 (.75 is aspect ratio)=7.82"
    7.82"x2=15.64" +16=31.6"
    31.6"x 3.14=99.3" or inches round the tire(best to just roll 1 turn and mark!)
    now divide 63360/99.3(or a better 1 roll #)=638 ...thats your tire rpm
    now find the gear you are in and multiply. This will be close to finding say 4.1 from 3.9 axle ratio, but it has some room for uncertainty
    (edit) a true mathemetician could simplify that set of data im sure.
  16. Oct 6, 2009 at 7:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Fwiw....the "265" is actually the Section width.....not the tread width. ;)
  17. Oct 6, 2009 at 7:52 PM
    Tacoyota
    08 4wd
    good point. wont effect that number assualt luckily:D
  18. Oct 6, 2009 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! true.
  19. Oct 6, 2009 at 7:55 PM
    SSrUs
    SSrUs Member
    Damascus, Oregon USA
    '09 4x4 SR5 Access Cab 2.7L M5
    3" Lift, Nasta Step Bars
    You don't need to dismantle the differential to find out. It can be checked somehow by blocking the front tires and jacking up one rear wheel. Then have a buddy rotate the wheel by hand one revolution while you count the revs of the driveshaft. I believe if you have a 4.56, one rev of the wheel equals 4.56 revs at the driveshaft.
  20. Oct 6, 2009 at 7:58 PM
    Tacoyota
    08 4wd
    when I was 20 the math might be easier. Now that I'm 40 I like your idea with the jack!
