regear needed in my 2.7L
Discussion in '4 Cylinder' started by kodiakisland, Jun 14, 2013.
  1. Jun 14, 2013 at 5:59 PM
    kodiakisland
    kodiakisland [OP] Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I like my truck, but there are some hills that I can't make in 2 or 4 hi with the factory setup. It's fine around town and on the highway, but sucks when I have to go to 4lo just to climb steep hills that don't even require 4X4 from other vehicles. I am also planning to go up one size on the tires to 265/75/16s which will make this even worse.
    I am planning to go to 4.56 gears with the taller tires, I just wonder if this is enough. I want better than I have now, not just a return to factory specs.
    Anyone running 265/75/16s with 4.56 gears? Is it giving better low end than factory gears and tires?
    Most of my driving is under 65mph so I'm not really worried about MPG on the top end, but do make one or two long drives every year and want to stay decent at 75mph.
  2. Jun 14, 2013 at 9:16 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    If you need 4lo now then 4.56 will not do it.
  3. Jun 14, 2013 at 9:50 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    It's rather annoying how little power the truck has going up a steep hill. I realize they gear them for the best mpg at highway speeds, but sometimes it's ridiculous. First gear could have been made a bit lower than what it is.
  4. Jun 18, 2013 at 4:15 PM
    bajatrailrider
    bajatrailrider Bajatrailrider
    Larry
    CALIF
    12 prerunner SR5
    Prerunner bumper,Lifted 4-3
    Gear down good idea.My truck DC 2WD 4SP auto 4 banger (when it had stock tires)over 95 in third gear.It has 4.10 gears now 32in tires. Im told 4.56 gears
  5. Jun 18, 2013 at 6:28 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I run 235/85 16, the same height roughly as the 265s, 4.56 gears. Simply put, they feel the same mostly after you add the tires, about 150 rpm more at 65mph. I have headers too fwiw. If you plan to do a lot of 4 wheeling , you'd better go 4.88 or so. In the end you wont get around it being the 4 cylinder really.
    be mindful if your state allows 75mph and you do 4.88+ you might not like the high freeway rpm's, that's the tradeoff.
    The 4 cylinder suits me because most off-roading I do is on back properties, often trying to roll along at 2500-3500 rpm to keep it smooth, tree weaving at times. I'm really not into rock pits and mud oceans.
  6. Jun 18, 2013 at 6:31 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    My 33's (285/75/16) have made my truck a dog. In in the same boat as you. 2/4hi is useless when it comes steep inclines. 4lo is need to climb anything remotely steep.
  7. Jun 19, 2013 at 6:54 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    What do you mean by pinned?
  8. Jun 28, 2013 at 2:21 PM
    Longo118
    Longo118 Well-Known Member
    New York
    2006 4x4
    -OME Lift w/ Dakar leafs -Wheels + Tires -All Pro IFS skid -4xInnovations Sliders -Tool box, hi-lift, shovel mount and a few others
    I definitely feel I need to regear as well, but I dont think I have it as bad as you guys. I wheel my truck atleast 2-3 times per month, some are big trips while others are just messing around in trails at someones property. I run 265/70/17s (31.6 tall) which definitely makes my truck sluggish but it is also a daily commuter for me, plus I have aftermarket bumper, bed rack, tool box, lift kit, sliders, skids and much more. Every few months I trailer a nice load of equipment back and forth (approx 2,500lbs) and the truck is definitely taking a beating but I never once have to put it in 4x4 to go up hills. I'm surprised to see you guys are having such troubles climbing hills in 4x4.
    I was told a few times to consider 4.56's for a nice mix of highway/offroading.
  9. Jun 28, 2013 at 11:35 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    It's not that I need the 4WD to get up the hills, I need the torque of low range to climb steep hills at speeds less than 5 mph. There is no road on the hills I'm climbing, but 4WD is usually not needed. In 2 or 4 high there simply isn't enough torque to keep momentum without dying.
  10. Jun 30, 2013 at 7:44 PM
    Longo118
    New York
    2006 4x4
    Ohhh gotcha. Sorry I misunderstood
