Regear or supercharger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stickyTaco, Sep 27, 2021.
  1. Sep 27, 2021 at 1:26 PM
    stickyTaco
    stickyTaco [OP] Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Long story short, I'm looking for some more grunt for towing a 3,500lb trailer off road. I have 285s with an AT and stock 3.73 gearing.
    Plan was to regear to 4.56 but I'm concerned that'll cause pretty high RPMs when towing on the highway and I have to keep it in 4, which has led me to the supercharger option.
    I know it is a deeper rabbit hole but I'm beginning to think a little boost will be a better solution and should be sufficient with factory gearing in 4L off road.
    Kolter45 likes this.
  2. Sep 27, 2021 at 1:31 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    I4 or V6 ??
    regearing is going to run the engine several rpms higher
    ALL the Time..........
    the supercharger ..........AFTER U get the tune right will be running All the time
    the SC will cost more to obtain & get right
    many times more than a regear
    in for a nickel..............in for a dollar
  3. Sep 27, 2021 at 1:31 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I did boost before gears on my 3rd gen for towing and have been extremely happy with the result. Probably going to be doing gears soon though....
    Formidable and stickyTaco[OP] like this.
  4. Sep 27, 2021 at 1:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Not sure the 'best' answer, but I'd suggest considering.......
    Driveability for solving your immediate issue.
    Driveability for the other 90% of not towing. (Assume it's a daily)
    Potential impacts on reliability
    OTD cost for each setup.
    Ongoing costs for each setup
    Other considerations?
    whatstcp and boston23 like this.
  5. Sep 27, 2021 at 1:51 PM
    TacoTuesdayNJ
    TacoTuesdayNJ Well-Known Member
    Id suggest re-gearing first always. You are already under-geared with the larger tires on there. Do you have extra weight on your truck? You would also want to be properly geared for that. That's a whole lot of extra strain on your trans pushing oversized tires already and the extra rotating weight. Fix that, with the proper gears and you wont be making your trans cry any more and you will have much more torque on tap. Instead of throwing extra horsepower at your undergeared drivetrain, just to over work everything into pushing you forward.
  6. Sep 27, 2021 at 2:13 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    @ROAD DOG, 4.0. The supercharger is about 2x the cost of the regear but that is not a concern at this point.
    @TacoTuesdayNJ, No concern with running for extended periods in 4 on the highway since I can't tow in D? I believe I'll be close to 3,000rpm with 4.56.
  7. Sep 27, 2021 at 2:15 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  8. Sep 27, 2021 at 2:15 PM
    coopcooper
    alberta canada
    probably supercharger first though, more power is always nice
    Buttskevin21 and stickyTaco[OP] like this.
  9. Sep 27, 2021 at 2:35 PM
    wormfood
    wormfood Well-Known Member
    David
    Missouri
    2011 Tacoma TRD
    TRD Super Charger, UWS, All Pro expedition leaf spring pac, Icon stage 4 suspension, B.A.M.F LCA Skid plates, TC weld-on upper coil bucket tower gussets, TC weld-on spindle gussets with sway bar mounts. RTT, Thule Roof Rack, Thule, Leitner Active Cargo System, Warn Zeon 10 Winch, All Pro Front Bumper, All Pro Apex Sliders, Nilight - 60005C-A 20Inch 126W Spot Flood Combo Led Light Bar.
    All solid and valid points from @TacoTuesdayNJ , I experienced all of this in one fell swoop after adding new suspension all around, 255/85/16s, and other weight. Front bumper, wench, ARB fridge, bed rack, roof rack, gear and a couple hundred pounds of labradors. Drove it from Texas to Anchorage Alaska and did I ever see my mileage drop. I've learned to pack better, less wind resistance, makes a difference but I never regret that TRD supercharger. Not only does it still make me giggle, but it's a blessing when I'm towing or just running the hills or mountains.
    I do plan to add a regearing eventually, so I can get everything out of it, that it's meant to give. It's on a 2011 double cab short bed.
    stickyTaco[OP] likes this.
  10. Sep 27, 2021 at 2:44 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    3pooches and stickyTaco[OP] like this.
  11. Sep 27, 2021 at 2:46 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    That's the plan. I'm thinking boost now, regear next year, then dive into supporting tunes for the supercharger.
    3pooches likes this.
  12. Sep 27, 2021 at 2:49 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Supercharger sounds fun. Tune with HPTuner and @JustDSM
  13. Sep 27, 2021 at 2:57 PM
    Kelvin
    Kelvin Wheeeeee
    This too. He can remote tune for you. Lots of good reviews from the guys in that thread I listed above.
  14. Sep 27, 2021 at 3:05 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    An F-150 will solve all of that for you.
    boston23 likes this.
  15. Sep 27, 2021 at 3:17 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Solve one problem but create 10 others. No thanks.
  16. Sep 27, 2021 at 9:42 PM
    TacoTuesdayNJ
    What are you towing are you at max gvrw for weight? If you re gear you should actually be able to use overdrive again on flat surface.
    Off topic. do you have a heavy duty trans cooler?
    SR-71A likes this.
  17. Sep 27, 2021 at 10:39 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    I have a larger aux transmission cooler and monitor the temp when towing. When towing in D the transmission fluid heats up as the torque converter locks/unlocks. It's a nonissue when not towing as my transmission temp on the highway and going over the local passes is always within 10°f of the coolant temp.
    My previous camper was 5,500lbs loaded and I have over 6,000 miles of towing that. The new camper is 3,500lbs loaded and it is the same height and width as the truck. I was running 32s with the last trailer and I'm on 33s now.
    Truck has extra weight...bumper/winch, sliders with fill plates, skid trilogy, rear hc bumper with a swingout. I also have a shell, rtt, a second spare, and 250ish lbs of gear when loaded up. 50/50 road/off-road use. Road use is daily around town and it sees highway trips with 500+ paved miles a few times a year. I drive it about 6,000 miles a year.
  18. Sep 28, 2021 at 5:40 AM
    woods_24
    woods_24 Well-Known Member
    2009 Black TRD Sport DCLB
    I'd do both. If I was to prioritize, regear first, then boost.
    rob1208 likes this.
  19. Sep 28, 2021 at 8:44 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I would re-gear first, no question.
    Less stress on the trans and that's certainly something to consider since you tow so much and have a lot of extra weight on the truck.
    I run a 285 Toyo Open Country AT3 which is a true 34" tire. Prior to that, I ran a BFG 34/10.5/17 which actually measured about 33.25" in diameter. That's the last tire I ran on stock gears and holy shit I hated being under geared. The truck was an absolute pig and I didn't have half the weight you have on your rig and I never towed. So I'm not even sure how you're making it right now. With the current 34" Toyos and 4.56 gears it's pretty good. That gets the final gearing (to the ground) pretty well close to stock.
    I feel like a super charger will be nice at altitude but as you add air you'll add fuel so expect that mileage to decrease. Keep in mind that if you open the diffs to install gears you could throw a locking diff up front for pretty much no additional labor. Since mine is a TRD Sport (open diffs) I installed a front and rear ARB locker when I did gears and it was the absolute best decision I ever made. Keep in mind, your shorter gearing also helps with descent control when you're offroad and doing really crazy steep downhill sections and need control. :)
    cryptolyme, RaginTxn and SR-71A like this.
  20. Sep 28, 2021 at 8:55 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I agree with those saying re-gear. Im a little bit surprised you've made it this far on stock gears, to be honest haha
    Theres really no reason to worry about running 3k RPMs.
    Also, Id probably want to drop the transmission pan clean the magnets and get some new fluid in there with all the towing youve already done
