Regear Speedo Help, Please!
Discussion in 'General Tacoma Talk' started by matt87109, Nov 13, 2023.
  1. Nov 13, 2023 at 11:59 AM
    matt87109
    matt87109 [OP] Member
    I've read countless posts and can't figure this out due to varing configurations. I have a 2009 5-lug 2wd with manual transmission. I regeared and found out my speedo is off. Why you say?...because the wheel sensor is used and your gears don't matter? That's actually incorrect for the manual transmission as only the automatic uses the abs sensor in this year and the manual uses a gear pick in the tranny (why did you do this toyota? Why?). Furthur more, I can't tell that toyota has different gear/teeth count options so I can fix by swapping tooth count.
    In any case, I went from 3:31 to 4:10 (love it), but my speedo/odometer are clicking away at 90 plus mph when gps says I'm at 75 mph.
    When i search hypertech's website for this calibrator thingy, they don't have a product listed for 2009 2wd manual tranny.
    Any help from people that have solved this would be greatly appreciated.
