Regearing a 5-lug
Discussion in '4 Cylinder' started by Natemx, Sep 24, 2010.
  1. Feb 2, 2011 at 4:57 PM
    #41
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    ok i'm not sure why this hasn't come up yet but someone on here just told me the rear end in the 5 lugs are all 7.5"... In the post above your talking like we have an 8.4"... Why is there soo much contradicting info on the rear ends to the 5 lugs??
  2. Feb 2, 2011 at 5:01 PM
    #42
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
    from what i have read we are the 8.4. there are a few members on here that have swapped an 8.4 from other trucks and had success.
  3. Feb 3, 2011 at 1:35 AM
    #43
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    The 05+ minis have 8.4 the 04 and below minis have the 7.5
  4. Feb 3, 2011 at 9:30 AM
    #44
    comiesutra
    Greenwood, IN
    good catch, I forgot that information.
  5. Feb 3, 2011 at 9:58 AM
    #45
    87xjmike
    Folsom
    98 5lug 2rz
    great thanks guys, all the contradictions make sense now as their was a year separation. so did the newer 8.4's come spring under just as my 7.5 did? I'll look for one of them if so, that'll make re-gearing much easier.
  6. Feb 3, 2011 at 10:36 AM
    #46
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    the 05+ 5 lug trucks are spring under
  7. Feb 3, 2011 at 12:47 PM
    #47
    NakedTacoma
    West Covina
    All minis came spring under
  8. Jun 2, 2011 at 5:13 PM
    #48
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    So i need a third member from a prerunner tacoma (non TRD or e-locked) and it'll bolt up to my 5 lug's rear end?
  9. Jun 2, 2011 at 5:53 PM
    #49
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Yes search for 3rd member from 4cylinder 4x4 or prerunner with 4.10 gears, the highest gears to come in any Tacoma stock.
  10. Jan 26, 2017 at 8:23 AM
    #50
    Jegbas88
    Jegbas88 Well-Known Member
    Indiana
    2017 TRDOR- manual
    TRD pro fox suspension, debadged
    I swapped 2005 tundra TRD 3.9 limited slip into 2005 2wd 5spd-3.31 simple swap.ean 31x10.50 & big power increase. Since pulled when sold truck.for sale 3rd- $350
  11. Oct 20, 2019 at 5:38 PM
    #51
    Jaffa_man
    Jaffa_man Member
    05 base Taco 5 lugs 2x4
    Are you selling this?
  12. Oct 21, 2019 at 8:35 PM
    #52
    Jaffa_man
    Jaffa_man Member
    I know this is an old thread, no one had a successful swap story to share on 2x4 2.7l 2nd gen 5lug?
  13. Oct 22, 2019 at 4:14 AM
    #53
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    You can't just swap axles between 5-lug and 6-lug. 5-lug are spring under and 6-lug are spring over. It can be done, but you would need to cut off the spring and shock mounts and reweld them. If you just want to swap the 3rd member, you need to use the 3rd member out of a non e-locker axle. The e-locker axle has a different flange and the 3rd members don't swap.
  14. Oct 22, 2019 at 5:07 AM
    #54
    Jaffa_man
    Jaffa_man Member
    Thank you for the great info,
    I am planning to get a 3'rd member of a non e-locker. I am corresponding with a guy selling his 2005 Tunrda 3.91 with LSD. Would that bolt on straight to my 10 bolt axle and has the same pattern as the drive shaft flange?
  15. Oct 22, 2019 at 6:23 AM
    #55
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    As far as I know the 3rd member flange will be the same. I'm not sure what you're referring to when you say 10-bolt. The non e-locker axle is referred to as the 8.4, and the e-locker axle is referred to as the 8" e-locker.
    You'll have to have to get driveshaft flange measurements to know if they're the same. I would guess that they'll be the same, but I have no actual info.
  16. Oct 22, 2019 at 2:11 PM
    #56
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    Given that the Tundra received the 4.0 engine in 2005, i'd say the odds are that if it's a non TRD Tundra, it'll fit.
  17. Nov 7, 2019 at 11:47 AM
    #57
    Jaffa_man
    Jaffa_man Member
    I have an 07 2X4 2.7l 5 spds 5-lugs with 3.31 ratio and 235/75R15s.
    I have done a 3'rd member swap from an 09 4x4 V6 with LSD and 3.73. It was straight forward, new member bolted on directly, no machining or anything crazy like that.
    The truck is running much better than before, day and night but nothing crazy. MPG is almost the same. Now the speedo started reading 7.5 MPH more than the GPS. I had to replace Existing speed sensor (27 teeth) to one with 29 teeth (part number 3340339515).
    While I am at it I also did change the axle seals and put new Diff oil and added LSD additive.
  18. Dec 11, 2019 at 9:45 AM
    #58
    pwrslide2
    pwrslide2 Well-Known Member
    AZ
    07' 2.7 2wd auto
    In process
    I'm in the process of looking for used parts for my 07' 2wd 5 lug 4cyl. door jam code says A01A which is supposedly a 3.42. very sluggy on highway even with stock 215/70/15 tires.
    Suspension needs replaced (all of it), as well as my tires so I'm looking at upgrades. I've already acquired 16x8 +30 wheels. I think I'm going minimum lift with no larger than 30's. Was actually thinking a little bit of a power bump with 3.73s and 29's. 29" = 235/70 or 29.6" = 245/70. wont be going offroad much at all.
    Ideally I need to collect the parts for a 3.73 LSD rear end. or open 3.73 and get a manual locker setup.
