Regearing and Low range
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tweeek, May 10, 2014.
  1. May 25, 2014 at 5:31 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    its all relative, the 4 cyl starts out with 4.10's so if you go up in tire size the 7.5% then you will need to go up in ratio just as much. So 4.40's
  2. May 25, 2014 at 5:36 PM
    Pinoiako916
    Pinoiako916 Well-Known Member
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Thank's for the advice on the re-gearing!
  3. May 26, 2014 at 10:38 AM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    Lastly, what are the benefits of re-gearing a V6, for example to 4.10 or even down to 4.56/4.88 in terms of power, and off road performance?
  4. May 26, 2014 at 10:54 AM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Its not worth regearing a v6 to 4.10 not enough of a difference from 3.73. Also not worth regearing for 33's unless your putting in lockers at the same time. With a regear you get a good junk of torque back since you gain mechanical advantage. Regearing to 4.56 or lower takes stress off of the driveshaft, transfer case and transmission as well. Also lowers your crawl ratio which is helpful offroad.
  5. May 26, 2014 at 12:31 PM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    For a 4 cylinder 4WD Tacoma, the gears are 4.10. If I want to put in 33-35 inch tires on a 4 banger, do you suggest 4.56 or lower as well?
  6. May 26, 2014 at 12:59 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    4.56 for 33's and 4.88's for 35's
  7. May 26, 2014 at 1:14 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Folks typically regear the V6 to 4.56 and the 4 cyl to 4.88.
  8. May 26, 2014 at 1:15 PM
    tweeek
    tweeek [OP] Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    This thread really got sidetracked lol
  9. May 26, 2014 at 1:18 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    To answer your original question - yes you can feel the difference after regearing for off-road and yes it's better.
    That said, if you're looking for a quantum improvement by leaps and bounds, a BIG change - well as you already know the only way to get that is to go to the crawl box.
    I'd say if you're already committed to eventually getting a crawl box - just save your money toward that goal and don't bother with the interim step of regearing.
  10. May 26, 2014 at 1:26 PM
    Pinoiako916
    Al
    Roseville,ca
    SR5 2.7 4x4
    Stock
    I do not plan to put in even more bigger tires (i.e., 37-40 inches).This is because I plan to keep front suspension IFS and have an expedition build.
  11. May 26, 2014 at 1:31 PM
    tweeek
    Victoria, BC
    Thank you. This seems like solid advice, and is pretty much my thinking at this point too.
