Regearing checklist
Discussion in 'Performance and Tuning' started by cbcs1987, Nov 28, 2010.
  1. Nov 28, 2010 at 4:18 PM
    cbcs1987
    cbcs1987 [OP] Redneck from the hills
    Cody
    East Tennessee
    2007 Tacoma 4wd access cab
    6" Fabtech coilover lift. 35/12.50/17 Mickey Thompson MTZ, 17x9 ProComp 1089 wheels painted black, UWS black lowprofile toolbox, husky liners, tacoma bed mat, bed lights, Premier stereo, Cobra 19 cb, firestik 3' antenna.
  2. Nov 28, 2010 at 4:20 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Gears, install kit, and locker if you plan on knocking that out at the same time...really there is nothing else needed and if a small part is the shop installing it should have it available for you! I will be having gears and an ARB air locker installed sometime soon.
  3. Nov 28, 2010 at 4:23 PM
    cbcs1987
    Cody
    East Tennessee
    I've thought about locking it but can't decide. I wonder how much extra that would be to have installed?
  4. Nov 28, 2010 at 4:27 PM
    cbcs1987
    Cody
    East Tennessee
    I don't see that on east coast supply's site. Know where to get one?
  5. Nov 28, 2010 at 4:56 PM
    08pretaco
    az
    ECGS will sell you the flange if necessary. If your spending the money to install the gears I personally think a locker, if you plan to in the future, should be installed at the same time to cut down on unnecessary spending.
  6. Dec 1, 2010 at 10:55 AM
    cbcs1987
    Cody
    East Tennessee
    Ok, so I need to order a quantity of 2 from the link posted above, and a different pinion flange...and thats all?
    Also, what do you mean when you say "whole third." I know NOTHING about gearing.
  7. Dec 1, 2010 at 5:53 PM
    08pretaco
    az
  8. Dec 1, 2010 at 8:38 PM
    cbcs1987
    Cody
    East Tennessee
    I've gotta v6 so I guess it is the 3.73 rear end... Non Trd so no locker
  9. Dec 2, 2010 at 8:10 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    If your having gears installed then a locker shouldnt add to the labor cost, you should do at this time to save you a big chunk of labor down the road..the carrier needs to be removed during a gear change anyway, and the locker will replace the stock carrier.
    FYI the carrier is the main part in the differential that the ring ger is bolted to..
  10. Dec 2, 2010 at 6:28 PM
    cbcs1987
    Cody
    East Tennessee
    Ok here's my next question. I'm reading about people on this site regearing the front and rear and paying just over a grand for parts and labor. If I am reading right... Parts from ECGS alone will cost me over a grand without a locker. Something isn't adding up. That price is coming from the links 08pretaco shared with me
  11. Dec 2, 2010 at 8:38 PM
    08pretaco
    az
    Regearing is an expensive thing. I just called an offroad shop near me, for gears, install kit and gear install with ARB install (not purchase)....1100 bucks just for the rear
  12. Dec 7, 2010 at 7:15 PM
    hanapepeboy
    hanapepeboy Active Member
    Talon
    Hawaii
    2002 TRD Tacoma 4x4 2.7L
    6" Fabtech Suspension Lift 3" Body Lift 3" Gap Guards 5.29 Yukon Gears 35/12.5/15 baja claw radials 15"/10" Mickey Thompson Classic 2s AFE Stage 2 Dry Intake Debadged Disable DRLs 6000K HIDs No Mudflaps Interior: Alpine Deck Rockford Amp 10" Type R
    installing gears is quite pricey, i bought 5.29s for front and back with installation kits and a new flange and it ran around a grand, and it was more for installation
