Regearing for 33s. 4.30 vs. 4.56
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justinf307, Dec 15, 2017.
  1. Dec 15, 2017 at 7:23 AM
    justinf307
    justinf307 [OP] Well-Known Member
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Planning on regearing to help accommodate for 285s, and the extra weight. Now that 4.30 is available for the front diff also I would like to hearssome opinions about both. How many of you that went 4.56 would've gone 4.30 if given the option now. I still use the truck as a DD/ weekend warrior now. We recently picked up a jayco 174bh which is about 3500 loaded so that really made the need for gears obvious.
  2. Dec 15, 2017 at 7:32 AM
    Pigpen
    Dan
    Northwest Montana
    Manual or auto transmission?
  3. Dec 15, 2017 at 7:33 AM
    justinf307
    Justin
    Glenrock WY
    2007 Tacoma DCSB
    Auto sorry!
  4. Dec 15, 2017 at 7:34 AM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    One thing about the 4.3 that seems cool, is that it is available stock on the 3rd gen, so you may be able to swap out junkyard clamshell/3rd.
    Coot83 likes this.
  5. Dec 15, 2017 at 7:36 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    are you V6 or 4cylinder?
    I never had issue with 33s and towing even through blue ridge mtns of east TN. But my 33s were lighter p-metric type tires, not LT type, so that may have made a difference.
    awylie0321 likes this.
  6. Dec 15, 2017 at 7:37 AM
    Pigpen
    Dan
    Northwest Montana
    I always ask. As a man trans, I'm torn between 4.10 and 4.30. You're on track for auto. The deciding factor will be whether you're regearing for the road or off road. Go lower for off road, but 4.30 will be better fuel economy while giving you back the power you lost.
    Truckdogipa2 likes this.
  7. Dec 15, 2017 at 7:40 AM
    Pigpen
    Dan
    Northwest Montana
    I'm pretty sure @Kyitty is happy with his 4.56, but he wanted moar powah for off roading.
  8. Dec 15, 2017 at 7:43 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have 4.56, 255/85s, and supercharged. I need a DD. Winter daily driving is killing the build. Or that I am not letting it warm up, so I am getting 10mpg..
    But 4.56s gave me more low end torque.
    JimboAnz likes this.
  9. Dec 15, 2017 at 7:48 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    4.56 auto on 255/85/16 here. no regerts. 14 mpg, with armor and weight everywhere........
  10. Dec 15, 2017 at 7:59 AM
    badger
    badger Well-Known Member
    07 SR5
    I have 4:56 with a manual and 33s, which is different. It definitely limits my highway speeds since the manual doesn't really have an overdrive gear. I actually wanted 4:30, but back then it was not an option. I'm thinking that 4:56 would be a good option with the auto if your truck gets used as a truck.
  11. Dec 15, 2017 at 8:03 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    4.56 if you ever want 35s or do a lot of slow rock crawling. 4.3 otherwise imo.
    but im also running 35s on stock 3.73 for almost 2 years. what do i know :notsure:
    ps. i have towed 3000lb load without any complaints
    realest2.7 and bski22 like this.
  12. Dec 15, 2017 at 8:05 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    4:56 on 285s. If I had to make a complaint it would be RPMs at freeway speeds but it’s really not that bad and by freeway I mean 80mph. I very rarely take the truck to that speed so it’s not that big of a deal.
  13. Dec 15, 2017 at 9:18 AM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Prolly been ask before but, What is the stock gear ratio in 2012 TRD sports?
  14. Dec 15, 2017 at 9:35 AM
    badger
    07 SR5
    For a manual transmission, the limitation comes in around 70.
  15. Dec 15, 2017 at 9:38 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    This.
    I went from 285s to 315s and am getting my truck back soon from the regear to 4:56s. IMO the uphills on 285s can get sluggish in stock gearing, but I wouldn't have regeared for 33's as my truck sees a lot more highway and doesn't need the higher RPMs and torque since I don't slow crawl much.
    The real question is...even if you say you don't plan to go to dirties...do you really believe that. I told myself that punchline for two years cause I didn't want to regear, but the trail schooled me up.
    Slashaar and desertjunkie760 like this.
  16. Dec 15, 2017 at 9:42 AM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    another option instead of regearing for 35s is using 4 for autos (which is what i do), pretty much the same as 5th regeared for highway use.
    i average 13mpgs fyi
    bski22 and Coot83[QUOTED] like this.
  17. Dec 15, 2017 at 9:45 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    The knowledge keeps on coming! :thumbsup:
    bski22 likes this.
  18. Dec 15, 2017 at 9:48 AM
    desertjunkie760
    Shane
    Check My Sig.
    I do that anyway, even with 4:56 because I do t like how the truck short shifts.
  19. Dec 15, 2017 at 10:05 AM
    Pigpen
    Dan
    Northwest Montana
    4 cyl is 4.10, 6 cyl is 3.73 for 6 lugs
    madsand[QUOTED] likes this.
  20. Dec 15, 2017 at 1:05 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    Thanks so mine will fall on 3.73. Debating on regearing too, leaning towards on 4.56 but then this thread pop out. Curious on 4.30
    hoverlover and Stryker420 like this.
