Regearing for 33's
Discussion in '1st Gen. Tacomas (1995-2004)' started by AeonLawson, Apr 4, 2018.
  1. Apr 4, 2018 at 4:44 AM
    AeonLawson
    AeonLawson [OP] Member
    Aeon Lawson
    Forest City, NC
    97 Tacoma
    I have a 97 Tacoma with the 2.7L (4 Cylinder) and a 5 speed transmission.
    Im putting 15x10 wheels with 33/12.50 tires on it and im just wanting to know what gear ratio to go with so the truck turns the 33's easier. Im not worried about gas mileage i just dont wont the truck to bog down going up hills and struggle with everyday driving.
  2. Apr 4, 2018 at 4:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    If it's 4wd, don't forget you'll have to change both diffs.
  3. Apr 4, 2018 at 6:20 AM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    I have the 3.4 V6 with a 5spd. I dropped in 4.88 gears with 285/75/16 tires. Setup is great all around. I lose a bit of top end Hwy performance cause I'm reving at 3000rpm when doing 70mph.
    You have the 4 banger. I would definitely spring for 4.88s
    BassAckwards likes this.
  4. Apr 4, 2018 at 6:23 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I've got 4.56 and 33's and it's good everywhere but hills. I tend to baby it and usually never go past 3500 RPMs though so it is mostly my fault it doesn't climb well. On the freeway at 70 I'm around 2700 RPMs. That was with a tired 300,000 + old engine too.
  5. Apr 4, 2018 at 8:51 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    4.88's if you do a bunch of dirt; 4.56's if you're generally on pavement
    Dalandser and Prayn4surf like this.
  6. Apr 4, 2018 at 9:20 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What gears do you have now? There's a code on your door sticker that tells you what you have.
    https://www.tacomaworld.com/threads/oem-gear-ratio-chart.365138/
    There are some online gear conversion charts that can help you. https://www.4wheelparts.com/off-road/gear-ratio-tire-diameter.aspx
    There are many others, too.
    Just try and match your RPMs at 65mph (current tires) with the new tire size and new gear ratios. 4:10s, 4:56s, 4:88's, or 5:29s
    Or just go with 4:88's, lol...
    arctic04trd likes this.
  7. Apr 4, 2018 at 8:53 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Lol, I have stock gears with 33's and my speedometer is a bit slower if you get my drift..I don't want to lose precious top end power, I do however have to baby my trans and rearend. I have a V-6 so its a bit different than a 2.7 I would definitely regear if I had a 4 cyl.
  8. Apr 4, 2018 at 9:40 PM
    AeonLawson
    Aeon Lawson
    Forest City, NC
    97 Tacoma
    Thanks for all the replys everyone. I think im gonna go with the 4:56 gears but would i also have to replace the front gears to??
    Dalandser likes this.
  9. Apr 5, 2018 at 3:42 AM
    Tbimm
    Tbimm Well-Known Member
    Tom
    Belle Chasse La.
    2000 Tacoma Prerunner
    Bilstein 5100's front and back. OME 880 front coils. General HD rear springs. Fuel 16x8 Enduro rims. Dick Cepek Extreme Country 285/75/16's Some kind of headers. K&N cold air intake.
    Yes the front and rear have to match or you will burn your transfer case up.
    Gatordawg likes this.
  10. Apr 5, 2018 at 5:17 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    You clearly don't like acceleration...:D
    I wasn't going to regear....till I tried taking off from a stoplight with 33s......suddenly I had a couple thousand to spend:spending:
    Poncate and turbodb like this.
  11. Apr 5, 2018 at 7:15 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    V6 on 285/75 R16’s here, and just went from factory 4.10’s to 4.56’s this year. It’s my only vehicle and occasionally I have to drive across country which kept me away from 4.88’s. I’m incredibly happy with the improvement. My first trip to the Denver area I went over Vail pass at 10,662’ and only dropped to 3rd gear for less than two minutes. On the way home to Grand Junction I never dropped below 4th on Vail. (not as steep west bound) In over 24+ years of driving that pass in a handful of Toyota trucks I’ve never had that kind of performance. Gears may just be the best mod ever. If you spend most of your time on pavement then 4.56 or 4.88, if you do a fair amount of off highway driving (and have a second vehicle) go 4.88 or 5.29. More torque is never a bad thing, after all your in a 2.7 Tacoma you’re probably not going to set a land speed record. I almost wish I had gone 4.88 with mine, but not to the point of kicking myself.
  12. Apr 5, 2018 at 9:06 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    My 1999 2.7 came with 31's and 5.11 gears. What tires do you think the previous owner had on there to need such hearing
  13. Apr 6, 2018 at 6:43 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Do you have a Ford rear cause I don't think you can get a Toyota in 5.11.
  14. Apr 6, 2018 at 10:10 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I have a 2.7 5 spd running 33x10.50s on stock 4.10s. For daily driving it's not bad at all, the place I want to gear down for is in the rocks. 4 low just ain't quite low enough with the 33's for crawling. If I could afford it I'd just do dual cases and leave the axle gears and be set for both on road and off.
  15. Apr 6, 2018 at 10:13 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    What he said...I like my 4.56 but its still my dd and I use it to explore and that always involves pavement, if its just gonna be in the dirt and rocks...4.88 all the way... i had great experience with ecgs and the least expensive option I could find. If youre gonna open the front up, put a arb locker in there:thumbsup:
  16. Apr 6, 2018 at 10:25 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    What do you do with the truck? Daily driver? Dedicated wheeler? Do you do lots of interstate driving? Is your truck heavy? What is your stock gear ratio?
    This will be a big factor in picking your gears. I don’t think 4.56 will be enough. My 2.7 has stock 4.30s and it struggled while towing and crawling rocks.
    4.88 would probably be a safe bet for the average user.
    I’m running 5.29 on my truck and I love it. Wouldn’t want any less. Note, my truck is a trail/play rig. It’s is over geared if you were going to use it as a Hwy commuter. Sits at 3k at 65mph.
    I would also note some of the input you are getting here is coming from people with the 3.4L engine. Your truck and theirs are not the same. We can’t make up for lack of gearing with power.
    Give ECGS a call and they’ll help you sort through your options. Good luck!
  17. Apr 6, 2018 at 10:39 AM
    AeonLawson
    Aeon Lawson
    Forest City, NC
    97 Tacoma
    The truck has stock 3:58 gears. I mainly do pavement driving because the truck is my daily driver but id like to start wheeling on weekends and be able to have fun offroad.
  18. Apr 6, 2018 at 10:47 AM
    solgardener
    solgardener Well-Known Member
    William
    '14 Tacoma DCLB SR5
    If you offroad, might as well lock it while you're in there. Especially the front. It's not exactly a few bolts and pull the diff like the rear.
  19. Apr 6, 2018 at 11:46 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Here's a video for the front :)
  20. Apr 6, 2018 at 11:59 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    That’s a really good one, as are all of his. I didn’t have nearly as much trouble getting the clamshell to come out as he did though.
    Dalandser[QUOTED] likes this.
