Regearing for 33's
Discussion in '1st Gen. Tacomas (1995-2004)' started by AeonLawson, Apr 4, 2018.
  1. Apr 6, 2018 at 12:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm thinking it could be the oil pan on a 3.4 in a 4runner that's giving him problems, but yeah it got me concerned about doing mine. I pulled my engine for other stuff and am going to do it all at once.
  2. Apr 6, 2018 at 12:19 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Maybe so. Don’t get me wrong, it was a little tricky, but no bad.
    Dalandser[QUOTED] likes this.
  3. Apr 6, 2018 at 2:27 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    As far as I was able to calculate from spinning the tires and counting drive shaft rotations I got 11 turns out of the drive shaft to 5 rotations of the tire. Maybe I did it wrong but the spedo was off by 20mph with 31's on it. And it was a stock Toyota taco axle.
  4. Apr 6, 2018 at 3:02 PM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
    Sounds like you have 4.56 gears. 20mph off seems really extreme too...
  5. Apr 6, 2018 at 3:43 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Well maybe it was 11 drive shaft rotation for 1 tire rotation. But that seems way off. Man it was about 9 years ago when I did it lol either way it was rediculous to drive. The speed governed kicked on at like 85mph on the speedo. When I put a new axle on with Elocker from a wrecked tacoma it brought the speedometer back to normal.
  6. Apr 6, 2018 at 4:44 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you had 5.11 then the drive shaft would spin a little over 5 rotations per 1 wheel rotation. Mark the drive shaft at the diff and try again.
    Stout890[QUOTED] likes this.
  7. Apr 6, 2018 at 4:52 PM
    eon_blue
    Azusa, CA
    I thought I was pushing it when I stretch the RPM's to 3k, haha. I usually try to shift below that or at it...my 3.4l is screaming pretty loud by the time I hit 3k especially in gears 1 - 3. The extra weight on the truck isn't helping I'm sure.
    edit: just realized you're 4cyl...I think those are meant to be revved higher so makes sense
    se7enine[QUOTED] likes this.
  8. Apr 6, 2018 at 6:36 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I've got super quick built streetbikes if I have the need, lol!:bikewheelie2:
    Dalandser likes this.
  9. Apr 7, 2018 at 3:30 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    Yeah I got rid of that axle long ago...shame though I had no place to store it and no one wanted it so I went to the scrap yard with whatever gears were in it. I should have pulled the 3rd member at least. Oh well. I was young and didn't know what I had was worth anything.
    Curious though what I have now I'll have to go out and check that one out and see. I always thought it was 4:10 but who knows now, everything I knew was a lie lmao. What did rear ends with E lockers come with?
  10. Apr 7, 2018 at 11:33 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    4.10s
    Edit: and 4.30s as well, just not very common
  11. Apr 8, 2018 at 4:35 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    Weren’t the 4.30’s on automatics?
  12. Apr 8, 2018 at 6:35 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I think that 4.88's are good with 33's on a 2.7 if your keeping the motor mostly stock. Especially since you have some pretty wide tires...more drag/rolling resistance.
    if you're going to add at power adder like a s/c or a turbo then go with 4.56.
    The 3rz feels much more powerful over 3k rpms than under.
