Regearing for 35s/37s...
Discussion in 'Performance and Tuning' started by StaticFilter, Dec 29, 2011.
  1. Dec 29, 2011 at 4:15 PM
    StaticFilter
    StaticFilter [OP] Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    I believe i am running 4.10s in my 98 3.4L 5spd right now, any suggestions on gearing for 35" or 37" tires in the future? This is also my daily driver so I need to maintain Freeway speeds, and with 154k miles i dont want to rev TOO high (5200 RPM MAX?) Should I go to 4.56 or 4.88 (or other)?
    any input?
    I don't know what gears I had in my 05 4.0L 6 Spd but the 35's were too much for it and 6th gear was worthless.
  2. Dec 31, 2011 at 4:27 PM
    StaticFilter
    Cedar Hills, UT
    Bump
    Also would it be of more benefit or cheaper to Regear for larger tires or do some performance upgrades like headers?
  3. Dec 31, 2011 at 4:30 PM
    rcfreak201
    rcfreak201 Well-Known Member
    in my 06 im running 35s and 4.88s. at around 70mph im near 3000 rpms. hopefully that gives you a little bit of perspective
  4. Dec 31, 2011 at 4:46 PM
    StaticFilter
    Cedar Hills, UT
    if you could fit 37's do you feel the 4.88s would be fine? are the 4.88s overkill for 35s?
    do you top out at 70MPH or thats the speed limit there?
  5. Dec 31, 2011 at 4:54 PM
    rcfreak201
    thats the speed limit, well 65.
    even up to 80-85 its around 3500.
    i think its a bit much for the 35s.
    if i could re-do it i would go 4.56
    35s=4.56s
    37s=4.88s
  6. Dec 31, 2011 at 4:56 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i have 4.88's and 35s and wish i geared lower 4.88's is normal ride for me though, i want more power
  7. Jan 20, 2012 at 5:23 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    I know I'm a little late to this party, but this page will probably be very useful to you:
    http://www.brian894x4.com/Gearratiosanddiffs.html
    It tells you the current gear ratio based on your VIN. I have a 12 DCSB TRD Off Road and that website tells me that I have a 4.56 gear ratio. I put a three inch lift on it and 285/75/16 tires on it and by doing the math, I should get 4.88 gears to maintain the power I used to have.
    (Old tires were 30.6" Diameter, new are 32.8" diameter = roughly 7% increase in circumference => gear ratio goes up by 7% to maintain power and speedometer readings. 4.56 X 1.07 = 4.89, which is close to 4.88)
    Maybe. That's all theoretical, I think. It might be different when you apply it, but I don't know cause I haven't regeared my truck.
