Regearing with 33" tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACLakey, Apr 28, 2012.
  1. Apr 28, 2012 at 11:55 AM
    ACLakey
    ACLakey [OP] Active Member
    Andrew
    Klamath Falls, OR
    12 Quad Cab Taco TRD
    How many here regeared when they went to either 255 or 285? I was thinking of a 3" OME, new UCA and 4.10 gears...any thoughts?
  2. Apr 28, 2012 at 12:02 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Do it.
  3. Apr 28, 2012 at 12:27 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    It seems many members on here are running 285 or 255 with stock gears (3.73). On the flip side, some members are also regeared since going up to 285/255s. check this link out. Just fill in the blanks and it'll tell you what are the prefered gears for a certain size tire
    http://www.tacomaworld.com/forum/tirecalc.php
    From what I've read, 4.10 gears are not readily made for our trucks. If you're planning on installing lockers down the road, when you get your gears put in that would be a good time to have the lockers installed also. Just my $0.02
  4. Apr 28, 2012 at 12:30 PM
    TacomaChris
    TacomaChris Well-Known Member
    Not necessary IMO; however, whatever floats your boat. I went to 285s and there is a marginal difference in my fuel economy
  5. Apr 28, 2012 at 3:25 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    You are right about it not being necessary, however, regearing eliminates the excessive wear and tear from spinning the larger tires.
    4.10 are not made after market. You can only get them used unless you buy them from the $dealer$.
  6. Apr 28, 2012 at 4:10 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    nobody makes the 4.10 aftermarket gears for our trucks yet.you will have to add a carrier to do the 4.10.go 4.56 4.10 will not even be a difference and they are 3x the price of 4.56.
  7. Apr 28, 2012 at 4:14 PM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    OME, Demello, 4xInnovations, Relentless, Murdered Click Sig Pic for Build Log
    I went to 4.56 from 3.73 with 285's and the difference is incredible. If you plan on adding any additional weight beyond new tires/wheels I would look at 4.56. If you are just changing your tires/wheels and adding a lift then 4.10 should be fine, but good luck finding them for sale.
  8. Apr 28, 2012 at 4:25 PM
    sooner
    TX
    2011-4X4-LONGBED
    copy taco,does your cruise stay engaged now at highway speeds?
  9. Apr 28, 2012 at 4:29 PM
    CopyTaco
    CopyTaco skeeert
    Kins
    Florence, OR
    2010 V6 4x4 DCLB
    Always.
  10. Apr 28, 2012 at 4:35 PM
    ACLakey
    Andrew
    Klamath Falls, OR
    Thanks for the feedback. My calcs showed that 4.56 may be a little low and may have a detriment on fuel mileage....who all has run 4.56 and what were your findings?
  11. Apr 28, 2012 at 4:42 PM
    sooner
    TX
    2011-4X4-LONGBED
    going from 3.73 to 4.10 is not worth the $$$.it is not enough difference to notice.you are only going to be running 200 more rpms with the 4.56 and will have better torque .
  12. Apr 28, 2012 at 4:42 PM
    sooner
    TX
    2011-4X4-LONGBED
    thanks copy taco
  13. Apr 28, 2012 at 4:45 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    Bogg, using that link - my new tires are 5.2% larger in diameter. Since I did not change my wheel size, just larger tires - the RPMs and distance sensor should show stock ratios. So to get an accurate mileage from the odometer, I should add 5.2%?
  14. Apr 28, 2012 at 4:54 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    changing your wheel doesn't mean anything.
    rpms work from engine load( bigger tire with stock gears makes the engine run in lower rpm. speed and odometer are affected by the bigger diameter. add 5.2% for distance,speed,mpg.
  15. Apr 28, 2012 at 5:18 PM
    Husker Tacoma
    Husker Tacoma Member
    Wichita KS
    Toyota Tacoma-TRD-Radiant Red
    6" Fabtech Lift, 18"x10" Mazzi Hulk Wheels, 33"x12.50" Toyo Open Country Tires.
    Just to let you know, I have 33's on my truck and I have never felt that it needed regeared. I have had multiple lifted trucks before including a chevy with 40" Super Swamper Boggers and I did have to regear to 4.56 with those, but I had 35" tires on before that and didn't regear. That was marginal. But with 33's on my tacoma I have never felt like it needed new gears. I may buy 35" tires next but I will wait to see how it drives before buying new gears.
    Just my 2 cents, take it or leave it. :)
  16. Apr 28, 2012 at 5:20 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Those calculators aren't accurate to the real world. Most 285's or 33's actually measure out smaller, like 31.8" or so. I have 4.88 gears and tires that measure out to 37", and it is lower geared than it was with stock 265's and 3.73's. My speedo reads faster than actual ground speed, when it says 109mph I am actually only doing 100. The point is, those calculators are only as accurate as the data you feed them. If you want more grunt go with 4.56-
  17. Apr 28, 2012 at 5:41 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    I run 255/85 R16's, stock gearing seems ok with them even offroad. I would only regear if you plan on locking or going to 35's down the road.
  18. Apr 28, 2012 at 9:20 PM
    Bogg
    Surrey, Canada
    07 TRD Sport 4x4
    http://auto.howstuffworks.com/car-driving-safety/safety-regulatory-devices/speedometer4.htm
    http://www.4x4offroads.com/gear-ratio-chart.html
    As stated above, these are just guide lines. Sort of like lifts. Some get vibes and others don't. Some have regeared and couldn't be happier with the outcome and others stay stock geared. Hence why the gear selector gives a range of gear ratios that could work. Better economy, closer to stock ratios and better performance. From what I gather, take the circumference of the stock tire and the circumference of your new sized tire. The difference in percentage will be the percentage your speedo will be out.
  19. Apr 28, 2012 at 9:21 PM
    Bogg
    Surrey, Canada
    07 TRD Sport 4x4
    Do you have the auto tranny? Another member on here was running 255s and found his tranny to gear search/ghost shift frequently with stock gears. I'm planning on running on 255s in the not so distant future
    KaptainH likes this.
  20. Apr 29, 2012 at 10:30 AM
    ACLakey
    Andrew
    Klamath Falls, OR
    I do have an auto tranny. I think I may go with 4.56 gears and put a locker in the front while I am at it....already have the rear locker.
