Regearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeansTaco6@9, Jun 30, 2025 at 3:32 PM.
  1. Jun 30, 2025 at 3:32 PM
    DeansTaco6@9
    DeansTaco6@9 [OP] Member
    Rob
    2015 trd
    None
    I mostly see write ups for the 3rd gens for regearing. Im curious about the differences for the 2nd gen.
  2. Jun 30, 2025 at 8:35 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    The 2nd gen is a much torquier motor so low end power is better. However generally the gear ratio recommendations are nearly the same.
    I have a 2nd gen on 35s, but with the 6mt. I chose 4.88 gears and I would not want to go lower. I top out at 80mph for comfortable rpm. Typically 5.29s are recommended for 35s
    33s are probably in the 4.10 and 4.56 ranges. I will let others confirm that though.
  3. Jun 30, 2025 at 9:48 PM
    Pigpen
    Dan
    Northwest Montana
    For the 4.0 non prerunner 6 lug you will maintain (roughly) stock gear ratios with:
    33" tires and 4.10 gears
    35" tires and 4.30 gears
    Getting into 4.56, 4.88, 5.29 benefits low range off-road driving, but makes the engine run at higher rpms to reach highway speeds, greatly reducing fuel economy.
    The most effective way to get truly low gearing is a second transfer case, aka crawl box.
