regular bed vs stepside bed
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Jul 24, 2010.
  1. Jul 24, 2010 at 12:10 AM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    are the stepside beds the same size as the regular xtracab beds?
    i know the doublecab beds are smaller so i don't need that confirmed
    thanks
  2. Jul 24, 2010 at 12:15 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    this question can be answered by another question....are you a vato in Los Angeles?
  3. Jul 24, 2010 at 12:27 AM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    lengthwise yes; widthwise no i dont believe it is the same but not completely positive. hope this helps!
  4. Jul 24, 2010 at 7:51 AM
    vantaco
    ha not even close
    ok so length wise they are the same. ya my thought was that it might be narrower
  5. Jul 24, 2010 at 8:04 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    The width of a step side should be about the width between the wheel wells on a regular bed. You will be loosing about 6-7 inches on each side.
  6. Jul 24, 2010 at 3:55 PM
    vantaco
    oh uhmm....what's the regular width between then?
    would i still be able to fit a full 4' sheet of plywood etc int he back? ( i don't car if it's a little longer over the tailgate, it's the width i'm worried about)
  7. Jul 24, 2010 at 5:49 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    it would be close my bed is a lil over 5 feet s if u were to lose a foot or so all together on a stepside then i would say yes a 4 ft. peice should fit into the bed but it will probably be a lil tight!
  8. Jul 24, 2010 at 5:55 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    I have some doubt it will fit. Sheets of plywood usually only fit between the wheel wells on a full size truck, where as on a smaller truck you would have to put the sheet above the wheel wells. The sheets only contact points will be the top of the ww, and it will not lie flat in the bed. Since you are loosing that space above the wheel wells in a step side, chances are the only way you can put the sheet in would be on an angle. But I could be wrong.
  9. Jul 24, 2010 at 6:03 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    I just did some measurements on my 2nd gen, and it's box is not even 5ft wide. The space between the wheels wells is also less than 4ft, so you could not fit a sheet between them. With the 1st gen being smaller than the 2nd gen, I don't see any chance of a sheet of plywood sitting flat between the wheels.
  10. Jul 24, 2010 at 6:09 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Well im going to take your word for it because i didnt actually have a way to measure it lol i was doing it by my wrist to elbow haha(my tape measure is in our fishing boat for rock fish measurements!!!) but i have had a sheet of MDF in mine just on top of the wheel wells, maybe it was a lil shy on the sides!
  11. Jul 24, 2010 at 6:26 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    Lol, yeah I was not trying to prove anything, just trying to get the OP some helpful info. :D
    That's the exact info he was looking for it seems, a 4ft wide sheet will fit in a regular bed on top of the wheel wells, but since that space does not exist in a step side, the sheet won't fit unless its on an angle with one side on the bed rail.
  12. Jul 24, 2010 at 9:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The distance between the wheel wells in a 1st gen is ~42" so a 4x8 sheet of plywood will not go between the wheel wells in any 1st gen bed. In a regular bed (not stepside) you can carry a limited number of 4x8 sheets but it will be above the wheel wells.
  13. Jul 24, 2010 at 11:54 PM
    vantaco
    ok thanks guys, i'll take a measuring tape with me tomorrow
    it's not a big deal and hauling playwood etc isn't the purpose for the truck....just wanted to know if it was possible (flat)
    thanks
  14. Jul 25, 2010 at 12:42 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    I found a good deal on a stepside a few month ago but passed it up because it's just too narrow for me. i think it's something like 9 inches narrower then then normal one, and the normal one is already pretty narrow. plus its not like our trucks are very high or the beds are very deep. I can reach right over and grab about anything in the truck. maybe the stepside would be helpful if you lift the truck and/or you're a short guy
