Regular cab bench swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rtrainor26, Mar 11, 2021.
  1. Mar 12, 2021 at 4:17 PM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    I dunno, it's pretty dang comfortable. I'm 6'1 and I can scoot the seat fwd a bit to gain recline.
  2. Oct 4, 2023 at 4:16 AM
    BaseTaco2wd
    BaseTaco2wd Member
    Stan
    2010 Base model Tacoma 2wd
    Can you do this and keep the air bags? Or do you have to disable them?
  3. Oct 6, 2023 at 7:10 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    You can keep the airbags. Just need to get seats that have them. I've heard there is a way to do it without getting the airbag light to turn on but didn't happen for me. Just need to get a reader that can scan and clear srs codes.
  4. Oct 6, 2023 at 9:18 AM
    CROM123
    CROM123 Love my Tacoma
    Garland
    Virginia
    2010 Tacoma 4x4 2.7 reg.cab. 27-k miles
    265/75/16 coopers at3 4s
    Very nice job it looks great!
  5. Oct 6, 2023 at 10:11 AM
    farmerfromkansas
    farmerfromkansas Active Member
    2014 regular cab base truck
    I am doing the bench to bucket swap today. Friend in the car business reminded me to unhook the negative battery cable more than 30 minutes before fooling with the wiring. So did that first, then some cleaning and watched the clock. It is noon hour, I have the drivers seat in and did grind the seat belt fitting to make it work with the latch. After lunch have to take apart both seats and swap in the wiring harness and the pressure plate. The drivers seat wiring connected just right. Both the truck and the buckets are 14 models.
  6. Nov 3, 2023 at 2:38 PM
    AlexNV
    AlexNV New Member
    Where can i get the brackets for the center console?
  7. Nov 3, 2023 at 3:13 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Afrer I did the bench seat mod it’s honestly the most comfortable seat and I’ve owned multiple Tacomas of all generations multiple tundras of all generations and multiple 4Runners of all generations, I drove non stop from SoCal to Bozeman Montana in my bench seat. Before I did the bench seat mod I was seriously going to sell the truck worst fucking seating position in the world
  8. Jan 25, 2025 at 6:13 AM
    Tacoma932
    Tacoma932 Member
    Sean
    2013 Regular Cab Tacoma
    for those that have done this mod, what are you doing for a center console? I have a 2013 (automatic), and I flipped my bench to buckets, but the shifter is in a slightly different place than the access or doubles, so the stock console doesn't fit, I was thinking of using a manual cab console as it looks like it is closer to the correct position for my model, but I'm just not sure how to hand the bag cover over a boxy auto shifter. anyone else have this issue? how did you handle it?
