Regular cab bucket seats?
Discussion in '4 Cylinder' started by stro1965, Nov 7, 2008.
  1. Nov 7, 2008 at 10:14 AM
    stro1965
    stro1965 [OP] Well-Known Member
    Bellevue, NE
    09 Timberland Mica Tacoma 4x4
    What bucket seats will bolt right in to my regular cab truck? I'm not liking the bench seat very much.
  2. Nov 7, 2008 at 10:17 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    The only bucket seats the somewhat *bolt right in* are ones from the same generation tacoma. Or seats off of summit that have a bracket for the tacoma.I custom made brackets for my 60/40 split bench that I had laying around
  3. Nov 7, 2008 at 4:22 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Higher-end aftermarket seats (e.g., Recaro, Corbeau) can be purchased with Tacoma-specific brackets / mounts from the vendor.
    Or you can check with Wedge Engineering (Long Beach CA), who specialize in seat mounting brackets.
  4. Nov 10, 2008 at 6:13 PM
    Synapse
    Synapse Well-Known Member
    Birmingham
    2008 Tacoma
  5. Nov 10, 2008 at 8:10 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    4 runner buckets may bolt in...not sure
  6. Nov 11, 2008 at 10:10 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    Worst idea toyota ever thought of was getting rid of the bucket seats in an sr5 regular cab for 2009.
    I love my bucket seats
    Railroader likes this.
  7. Nov 11, 2008 at 10:56 AM
    stro1965
    Bellevue, NE
    I'm new to Toyota. Are you saying that there were buckets available in a regular cab in '08? As far as I know, there were no changes and those would bolt right in (or be pretty close).
  8. Nov 11, 2008 at 11:04 AM
    hashemg
    Eastern MA
    There was a big change on the reg cabs between the 08 and 09 model...and that is that reg cab will only come with a bench seat.
    from 05-08....if you get the sr5 package on a reg cab..it would come with bucket seats
    i should say from 1985-2008 because an SR5 usually meant bucket seats
  9. Nov 11, 2008 at 12:01 PM
    stro1965
    Bellevue, NE
    So they might fit pretty good then? I realize that the mounting holes probably won't line up.
  10. Nov 11, 2008 at 2:51 PM
    Synapse
    Birmingham
    2008 Tacoma
    Yes, I remember looking at a singlecab pre-run with buckets.
  11. Nov 11, 2008 at 4:06 PM
    350TacoZilla
    Hancock MD
    my ex gf's 99 tacoma reg cab has buckets and center console in it... on my 96 and 97 the holes were there for buckets carpet just wasnt cut out around them
  12. Dec 25, 2008 at 11:41 AM
    JonO81
    JonO81 Member
    Central Wisconsin!
    09' Tacoma 2.7,4x4,5-speed
    Sound system, UWS high-pro.tool box, Aries bullguard/skidplate, upgraded to17'Tacoma sport rims.
    Thats a Good topic , because I feel the sameway!! I hate that bench seat!!! SO keep us updated so I know what i need to use when I switch mine out!!! tHANKS
  13. Jan 3, 2009 at 11:17 AM
    crazieN8
    crazieN8 ________________
    yorktown Va.
    95 4x4 taco
    3" lift, custom bucket seats, removable doors, KnN, eclipse sound system
    my 95 had a bench, i went down to pickNpull and sat in a couple dozen cars untill i found ones that were comfortable, ended up gettin a pair out of a brand new (totalled) pontiac, i had to make brackets all the way around. They do sit a little high so im going to look for another pair but it didnt take long to fab and you cant beat $35...
  14. Jan 3, 2009 at 11:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My 96 Extended cab had the bench seat when I bought it. I put 95.5 tacoma bucket seats and the center console from the same vehicle.
    The center console didn't have the same contour as the 'hump' in the floor. I was able to bolt it in, but it kinda rocked a bit. I didn't care....
    The buckest RULED!!!
    Sold the bench seat on ebay.
  15. Oct 12, 2009 at 12:39 PM
    biz_19
    biz_19 New Member
    2001 Tacoma 2wd
    Does anyone know what bucket seats may fit into a 2001 tacoma reg cab? I am looking to get rid of my bench seat and fit in buckets and a console. I've read through the previous threads and it seems it's possible to do in mid-90's models, I didn't see anything on early 2000 models.
    Wilgray2010 likes this.
  16. Oct 12, 2009 at 12:47 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Any bucket seats from 95.5 thru 2004 will bolt right in, no problems. I put buckets from a 2004 into my 97 and everything lined up perfect. All I had to change were the seatbelt recievers.
  17. Oct 12, 2009 at 5:09 PM
    biz_19
    biz_19 New Member
    2001 Tacoma 2wd
    Thanks Dave! I'll look in to the buckets from those years.
  18. Oct 12, 2009 at 5:55 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    DUHH! dang me :smack:!! I want to do a cover for the back area of my base/reg..... Think ill price an sr5 cab liner like in the photo. Wonder what the $$ is for that ... then bucket seats.
  19. Oct 12, 2009 at 6:58 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    LOL I must be the only person who likes their bench seats.
  20. Oct 14, 2009 at 3:05 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    nah i like it...not as supportive but the seating position is more comfortable imho...they sit a tad bit higher than the buckets.
    whoever's in the passenger's seat however, hates the bench....lol
    i sit pretty close up
