Regular cab howling when letting off throttle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by weeksz, Dec 20, 2019.
  1. Dec 20, 2019 at 12:43 PM
    weeksz
    weeksz [OP] Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Hey guys.
    I've noticed that I get a howling sound when coasting at around 55mph. When I get back on the throttle it goes away, only be when coasting. Seems to recently be getting more noticable but I did just swap to some winter M&S tires.. Don't think its that though. 160k, Manual Trans. Doesn't seem to be coming from the rear end but more like transmission/underneath me. I did an oil change the other day and everything felt right and tight. U joints are greased. Any thoughts on where to start poking around?
    Edit: I do have an add a leaf in the rear with 3rd gen swap suspension.
  2. Dec 20, 2019 at 2:55 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    That would be the infamous RC slip joint noise. It happens to lifted reg cabs and even some stock ones, but it's just a nuisance.
    Some have had luck flipping the shaft around, or adding a zerk to the slip joint and greasing often. Guaranteed fix's are a aftermarket drive shaft, or drive shaft spacer from 4crawler.
    There are a lot of threads on the issue :thumbsup:
    weeksz[OP] likes this.
