Regular cab leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Josh2755, Jun 27, 2014.
  1. Jun 27, 2014 at 4:56 PM
    Josh2755
    Josh2755 [OP] Member
    ON, Canada
    09 Regular Cab SR5 4x4
    trd offroad rims charcoal filter delete afe pro dry s drop in filter intake resonator delete lce header
    hey guys. i just picked up my first tacoma a few weeks ago, a 2009 regular cab 4x4 5 speed.
    i noticed the other day a little yellow sticker in the drivers door frame saying that 'this vehicle has been modified and the payload capacity is redused by 300 pounds'.. so i took a look at the leafs and it looks like it only has 2 leafs in the pack and looks like there has been one removed.
    Not sure why they would remove them and not sure what i should do now.
    Any ideas?
    PS, sorry if theres already a thread covering this, i did search and found nothing.
  2. Jun 28, 2014 at 12:44 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You should have 2 full leafs and 1 overload.
  3. Jun 28, 2014 at 1:36 AM
    2011flowedtaco
    2011flowedtaco Well-Known Member
    Antioch, California
    '11 aclb white trd sport 4x4
    Toytec ultimate lift kit, flowmaster dual exhaust, mb sport 17 inch rims, 33's coming soon
    And that's considered a "non tsb leaf pack" correct? Ultimately that's a 3 leaf pack then? My truck is the same was as the op's and have never really wondered until I read this thread.
    Thanks.
  4. Jun 28, 2014 at 2:54 AM
    Phils514
    Phils514 Well-Known Member
    Phil
    Dcsb
    I have the same sticker but it says reduced by 4lbs
  5. Jun 28, 2014 at 5:21 AM
    Josh2755
    ON, Canada
    Ok, well that sounds correct i do have 2 full leafs and then a bigger looking one on the bottom..
    In the straps for the leafs there is a big gap at the top.. looks like there was another leaf there at one point?
    And what would the sticker be for then?
  6. Jun 28, 2014 at 5:52 AM
    smd3
    smd3 Well-Known Member
    The trucks are rated for payload/GVWR as a base model. Options add weight, reducing that capacity, hence the sticker.
  7. Jun 28, 2014 at 5:52 AM
    Josh2755
    ON, Canada
    nevermind.. just did some more searching around and found out most 09 tacomas have the sticker.. but nobody really knows why, i guess ill have to try to figure that out
  8. Jun 28, 2014 at 8:59 AM
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    My 2014 Tacoma has the sticker. It takes into account the weight of the options; the carpeted floor mats and sill protectors, and the sliding rear window.
    5 pounds
