Regular cab u joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fairway605, Sep 11, 2020.
  1. Sep 11, 2020 at 8:59 AM
    fairway605
    fairway605 [OP] Member
    2006 Tacoma regular cab, 2005 Silverado reg cab, 2014 GMC reg cab
  2. Sep 11, 2020 at 9:06 AM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    DANA 513301X {Click Info Button for Alternate/OEM Part Numbers} Spicer Life Series (SPL); Greaseable Info [​IMG]
    FitsRear Driveshaft at Rear Axle; 1 Piece Driveshaft
    orRear Driveshaft at Transmission; 1 Piece Driveshaft
    orRear Driveshaft at Rear Axle; RWD; 2 Piece Driveshaft
    orRear Driveshaft at Support Bearing; RWD; 2 Piece Driveshaft
    orRear Driveshaft at Transmission; RWD; 2 Piece Driveshaft
    orRear Driveshaft at Rear Axle; 4WD; Crew Cab Pickup; Extended Cab Pickup; 2 Piece Driveshaft
    orRear Driveshaft at Support Bearing; 4WD; Crew Cab Pickup; Extended Cab Pickup; 2 Piece Driveshaft
    orRear Driveshaft at Transmission; 4WD; Crew Cab Pickup; Extended Cab Pickup; 2 Piece Driveshaft
    MY50cal likes this.
  3. Sep 11, 2020 at 10:09 AM
    fairway605
    Perfect, Thanks.
  4. Sep 13, 2020 at 7:17 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    I know this is the second gen forum but maybe you can help me? If not no worries I’ll start thread in the first gen section.
    I have a regular cab 4x4 First gen 1995.5 or 1996, I’m still not clear on when the cutoff for that is. It was made October 95.
    I had replaced my drive shaft with the one that has replaceable u joints at the cardan joint, I thought it was a spicer driveshaft but It’s been awhile and I can’t remember now. It had spicer u joints in it. Someone on TW recommended it to me.
    I’m also looking for the part number for all of those joints, the two in the cardan joint and the one at the diff. I can’t seem to find the information from when I bought the driveshaft to look up the joint part numbers.
  5. Sep 14, 2020 at 6:41 AM
    81shark
    https://www.rockauto.com/en/catalog...4l+v6,1278930,drivetrain,universal+joint,2392
