Regular cab with Prerunner suspension?
Discussion in 'Suspension' started by Mito, Oct 28, 2013.
  1. Oct 28, 2013 at 12:24 PM
    Mito
    Mito [OP] Member
    Los Angeles
    2006 Regular Cab
    I recently bought a 2006 regular cab tacoma and noticed that it's really bumpy. I might have to replace the shocks but figured that I may be able to buy someones stock suspension from the trd sport or trd offroad.
    Will these fit my truck?
    Will it lift my truck?
    I'm not looking for a lift i'm just looking to get a more comfortable ride.
    Mito
  2. Oct 28, 2013 at 2:57 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Does your truck have 5 Lugs or 6 Lugs per wheel?
  3. Oct 28, 2013 at 3:06 PM
    Mito
    Mito [OP] Member
    Los Angeles
    2006 Regular Cab
    It's a 5 Lug
    thanks Mito
  4. Oct 28, 2013 at 3:08 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Prerunner suspension won't work with the 5 lugs.
  5. Oct 30, 2013 at 9:20 AM
    Mito
    Mito [OP] Member
    Los Angeles
    2006 Regular Cab
    Not that i don't trust you but they seem like the same fit underneath? Is it the size of the shock or the spring will lift the truck?
    Can someone make a recommendation on new shock setup for a regular cab?
  6. Oct 30, 2013 at 9:27 AM
    darkgreentaco
    darkgreentaco XXXL Member
    NorCaL
    Timberland Rocket
    King RR C/O's, Extra mustard, All-Pro expdtn Leaf, sesame seed bun, Icon UCA's Fox Resi's BAMFsliders, sweet candy coating, LCAskids, diffcover 17" Addicts Yukon 4.56 Mt/r kevlar
    use the search feature of the website if you dont believe members.
  7. Oct 30, 2013 at 9:36 AM
    Runn0r
    Runn0r Well-Known Member
    NC
    07 Prerunn0r
    I thought about this too long ago before I bought a prerunner, but I read somewhere that the frame is different too and there's no real way to convert.
    -edit
    found link:
  8. Oct 30, 2013 at 9:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Have you looked at the 4x4 suspension and 5 lugger suspension side by side? They are nothing alike. 95Taco is correct, parts will not swap over.
  9. Oct 30, 2013 at 9:53 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    bilsteins
    /thread
  10. Oct 30, 2013 at 12:39 PM
    95 taco
    95 taco Battle Born
    Psst, the bilsteins won't fit the 5 lugs.
    The 5 lugs spring rests on the LCA and that's its perch, on the 6 lugs the spring perch is on the shock.
    6 lug shocks/springs
  11. Oct 30, 2013 at 12:57 PM
    Mito
    Mito [OP] Member
    Los Angeles
    2006 Regular Cab
    Thanks this makes sense!
    I didn't look at the button of the shock on my regular cab truck.
    Mito
