Regular engine oil or assembly lube when reassembling cylinder heads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Aug 26, 2015.
  1. Aug 26, 2015 at 3:47 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I'm just curious how using regular engine oil (5W30) compares to assembly lube when reassembling cylinder heads. Do you have preference for one over the other and why?
    Also, on what parts of the camshaft should I be applying cam lube ? That's the grease-like substance. Does that go on cam lobes only?
  2. Aug 26, 2015 at 5:17 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    assembly lube wont hurt especially if you arent going to start for a while. just change the oil after it runs for a bit. 50/50 oil and lucas oil stabilizer works too.
    foampile[OP] likes this.
  3. Aug 26, 2015 at 5:19 PM
    DEMikey
    mikey
    delaware
    2013 red taco
    when i worked at the dealer, i put it on everything. buckets, lobes, rockers, everything. biggest thing with assg lube, is it stays where you put it for initial startup.
  4. Aug 26, 2015 at 8:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Plain engine oil is too thin.
    Coat all cam bearing surfaces and lobes with a thick assembly lubricant. Bearing surfaces are more important than the lobes. Many moons ago we used straight STP Oil treatment ( consistency of honey ) for engine assembly lube. It also worked great.
    foampile[OP] and DEMikey like this.
