Regular or premium fuel in 3.5
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wrench71485, Jul 24, 2017.
  1. Jul 24, 2017 at 5:12 PM
    Wrench71485
    Wrench71485 [OP] Member
    Charlie
    Pembroke Massachusetts
    2017 tacoma trd offroad
    Working on it
    I cant find info on octane it says truck was tested at 91 i no its not required to run premium but seems better anyo e else running premium.
    nomnomtaco and Rambo54 like this.
  2. Jul 24, 2017 at 5:23 PM
    HardCase
    HardCase Winter is coming.
    Robert
    Kalispell, Montana
    2017 Tacoma (Inferno) TRDOR 4x4 DCLB
    87 is all you need. Anything more than that is wasting roughly 40 cents per gallon and buys you nothing.
    Having said that, I suspect you'll find that a number of guys are buying 91/92 because they think it's better. o_O
  3. Jul 24, 2017 at 5:28 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    doesn't the truck have a sticker on the gas door...
    poopshute and The hammer like this.
  4. Jul 24, 2017 at 5:29 PM
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
    Top Tier 93 ethanol free here.
    Rambo54 and shakerhood like this.
  5. Jul 24, 2017 at 5:29 PM
    Wrench71485
    Charlie
    Working on it
    Ok wasnt sure nothing really listed i have 2000 miles on truck idle seemed rough in trafic and thought should check
  6. Jul 24, 2017 at 5:30 PM
    Wrench71485
    Charlie
    Working on it
    It seemed to run better and my avg mileage went up at same speed and rpm on highway
    Rambo54 likes this.
  7. Jul 24, 2017 at 5:33 PM
    Wrench71485
    Charlie
    Working on it
    Sticker on door states e85 and ethanol no no's not octane well a minimum but in manuall said reasurched at 91 octane so that to me made me think to run 91
    Rambo54 likes this.
  8. Jul 24, 2017 at 5:35 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not on one tank it won't. Maybe ten tanks you can tell a slight difference. It takes a long time to self adjust timing for different octane.
  9. Jul 24, 2017 at 5:36 PM
    Drewskii6
    Drewskii6 Member
    Andrew
    Toronto, Ontario
    2017 TRD OR DCSB 4X4
    I'm in Canada but I doubt the manual changes much. Mine says minimum 87
    the_dau likes this.
  10. Jul 24, 2017 at 5:36 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  11. Jul 24, 2017 at 5:37 PM
    Wrench71485
    Charlie
    Working on it
    Oh ok want sure i had a two hour ride about half way fueld up
  12. Jul 24, 2017 at 5:39 PM
    Wrench71485
    Charlie
    Working on it
    Allso thought this engine adapted much quicker than others whith timeing and valve technology
  13. Jul 24, 2017 at 5:41 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
    I run 85 in colorado, am i hurting anything? i dont think so
  14. Jul 24, 2017 at 5:43 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Higher octane fuel
    Rambo54 likes this.
  15. Jul 24, 2017 at 5:44 PM
    Wrench71485
    Charlie
    Working on it
    So higher the octane the better
    Rambo54 likes this.
  16. Jul 24, 2017 at 5:48 PM
    Hank Heel
    WA
    Yes, run a couple of tanks worth of 92 and see if you can feel the difference and wether it's worth additional cost(¢20 in my case)
    I can say with certainty it's drives better, in that it responds better mid range, I don't care about actual hp, just better driveability.
    *Better is a subjective, so what's better for me may not be for you
  17. Jul 24, 2017 at 5:50 PM
    Wrench71485
    Charlie
    Working on it
    Ok will do thanks
  18. Jul 24, 2017 at 6:36 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    91
    Rambo54 likes this.
  19. Jul 24, 2017 at 6:37 PM
    blackcloud08
    WNC
    X2
  20. Jul 24, 2017 at 6:44 PM
    Sedyn
    Sedyn Well-Known Member
    Justin
    Vancouver, BC / Sumas, WA
    17' TRD Pro, Cement.
    87.
    Higher octane is designed to prevent detonation. Should be used in high compression and turbo applications.
    I don't see any need for it in this mild tune application.
    HardCase likes this.
