Regular or Synthetic Winch Cable????
Discussion in 'Off-Roading & Trails' started by Fern11, Feb 16, 2014.
  1. Feb 16, 2014 at 5:42 PM
    Fern11
    Fern11 [OP] Well-Known Member
    Karson
    Lake Charles LA
    11 Timberland Mica 4x4 6-Speed TRD Sport
    OME COMPLETE LIFT. 285-70-17 Dynapro's. 17x8 Pro Comp 7005.
    My first winch was damaged in a wreck last week, but insurance will cover another one so anything that awesome about the synthetic to make me get it or should I stay with the regular one?
  2. Feb 16, 2014 at 10:55 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Synthetic is better. Only downside is it's more $. If insurance covers it, get it :)
  3. Feb 17, 2014 at 12:01 AM
    TheGreatPear
    TheGreatPear Well-Known Member
    Alex
    Gunsan, South Korea
    2013 DCSB TRD OR 4x4 V6 6 Speed
    Synthetic line is lighter, stronger, easier to work with, and it won't destroy your hands if you grab it.
    Most importantly, synthetic line is far less likely to kill you or damage anything if it snaps.
    It can also be repaired if it does break.
    IMO it's borderline reckless to use steel wire anymore, with synthetic line being so advantageous.
  4. Feb 17, 2014 at 5:49 AM
    Fern11
    Karson
    Lake Charles LA
    Ok thanks for the input guys
  5. Feb 17, 2014 at 5:58 AM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    I prefer steel, but I use my winch to drag trees ut of the woods. Abrasion resistance is really the only benefit of steel.
  6. Feb 17, 2014 at 7:06 AM
    Fern11
    Karson
    Lake Charles LA
    Ok so I could either use some of the extra insurance money to upgrade to synthetic or use it for new step up bars and/or a 10" led bar. I have some people telling me that the synthetic isn't that crazy of a difference other than the few things yall mentioned above. But considering I'm a weekend warrior type of off roader what do yall think now haha.
  7. Feb 17, 2014 at 7:16 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i would say it's even that much more important for a weekend warrior. the safety benefits are tremendous, plus it reduces the weight hanging off the front of your truck by about 25 lbs. that's huge.
  8. Feb 17, 2014 at 7:42 AM
    Fern11
    Karson
    Lake Charles LA
    Oh really? Guess I'm leaning back towards synthetic....
  9. Feb 17, 2014 at 7:54 AM
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I just went synthetic but was wondering if the sunlight or weather exposure would break it down. Anyone?
  10. Feb 17, 2014 at 9:55 AM
    MJonaGS32
    MJ
    SF Bay Area (East)
    The only reason I went steel is because I was too cheap at the time. But with that being said, I've used my steel line plenty of times and it's worked perfectly fine every single time. The bigger part of everything is making sure you have a good winch. My Warn has outperformed my smittybilt tenfold.
  11. Feb 19, 2014 at 9:48 AM
    Indy
    Indy Master of all I survey.
    Most line is supposed to be uv resistant.
  12. Feb 19, 2014 at 10:31 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15Âş clocking
    In my experience, most synthetic line is "resistant" to UV, but not impervious. So, it does degrage over time. For me it goes like this:
    Steel
    Pros"
    Abrasion resistant (won't cut or chafe)
    Stronger for a given line diameter
    I've never witnessed, or heard of, a line failure
    Cons:
    difficult to work with (hard to spool neatly, can cut your hands)
    heavier per unit length
    If it breaks, it could kill you
    Synthetic Pros:
    Easier to work with
    lighter (more strength per weight)
    Packs neater/tighter on your winch
    If it breaks, you might only be injured
    Cons:
    Very susceptable to abrasion and cutting
    Wears with use. (and, to a certain degree, UV)
    I have heard stories of synthetic snapping
    I think, overall, you just need to pick the material that best suits your uses and needs.
  13. Feb 19, 2014 at 11:38 AM
    Fern11
    Karson
    Lake Charles LA
    thanks!
  14. Feb 19, 2014 at 7:42 PM
    Fern11
    Karson
    Lake Charles LA
    I actually have the money to get the same regular steel line smittybilt I had and get more aggressive tires with smaller wheels with my insurance money(my truck came with the 20" Enkei rims on it so I put terra grapplers on), or upgrade to synthetic, get nfab step bars, and possibly a light bar of some sort.
  15. Feb 22, 2014 at 9:04 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    I wouldn't agree with all your points.
    Synthetic is actually the stronger material.
    My group birdcaged a steel line in under 24 hours.
    The people who have busted steel line usually have harrowing tales and don't like talking about it
    I talked with the guy who received the original first production line of amsteel blue. He puts on Offroad classes professionally and product tests tons of stuff. His line finally broke 2 years ago. He pulled out a kit and repaired it in a few minutes.
  16. Feb 22, 2014 at 4:36 PM
    TRD 09
    TRD 09 Well-Known Member
    Alberta
    09 TRD sport
    I recently switched to synthetic, mainly to save weight, and it's ease of use. Plus it floats :)
    The weight reduction of the winch line and the fairlead was actually noticeable when driving
  17. Feb 24, 2014 at 7:13 AM
    Lumpskie
    New Hampshire
    I'm sure that people have actually broken their steel lines, I just haven't heard of anyone doing it. As for bird caging, that's part of what I was getting at when I said steel is harder to handle. It's hard to keep neat on the spool and you have to keep it neat. If you don't spool it correctly, you'll end up making a mistake like your friend there. That being said, you also need to pay close attention to the synthetic. I bet that guy with the amsteel kept a close eye on it to make sure it didn't chaff or fray over the 2 years he used it. Once it frays, it slowly degrades until it breaks, so it should be replaced. I still have steel line on my winch because I have winched with the line touching the outer edge of my hawse style fairlead. This would stress a synthetic line. I've also winched on the same line more times than I can count, for over 5 years without issue. I'm not trying to pick a fight here, but people also need to know that the synthetic line is more fragile in some ways.
