reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Aug 9, 2017 at 6:29 AM
    #461
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Who's all doing Morrison?
  2. Aug 9, 2017 at 6:55 AM
    #462
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Not entirely sure yet.
  3. Aug 30, 2017 at 7:17 PM
    #463
    Reh5108
    Idaho
  4. Aug 31, 2017 at 6:07 AM
    #464
    alee891
    Austin
    Black Hills
    Tacomaless
    Did you get rid of manny hubs?
    Reh5108[OP] likes this.
  5. Aug 31, 2017 at 7:02 AM
    #465
    cynicalrider
    cynicalrider #NFG
    Jersey
    Awesome pics Ryan! Looks like a great trip.
  6. Aug 31, 2017 at 7:22 AM
    #466
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Yeah, that area looks incredible! I definitely need to check it out one of these days.
    How long was the drive for you?
  7. Aug 31, 2017 at 9:26 AM
    #467
    Reh5108
    Idaho
    Yes. When I put the SPC uppers in I swapped back to ADD spindle and axle.
  8. Aug 31, 2017 at 9:29 AM
    #468
    Reh5108
    Idaho
    8.5 to the Morrison Trailhead. Probably 9 with stops for fuel. Hopefully you don't run out too. I made it to Riverton with the gas light on. Thought I was going to need to use the Jerry cans.
  9. Sep 16, 2017 at 6:41 PM
    #469
    Reh5108
    Idaho
    Checked compression on cylinder one tonight to see if it has changed at all. It hasn't. So that's good.
    I retorqued my front lugs since the studs are still fairly new and I don't really trust the 1/4" spacer. Lost about 15- 20 lbs on them. Torque wrench was reading around 60-65 ftlb. I torqued them to 80 when I installed.
    While the wheel was in the air I checked for any play. I have either slop in the rack or itrs. I think and hope it's the itrs. It's not much so I'm going to leave them until after RT. My front tires are already pretty low so I'm not too worried by the extra wear. Anyone hear of Moog itrs wearing prematurely? I think from here on out I'm sticking with OEM.
    As for the motor swap, I joined a crd jeep liberty page and they pretty much all recommended against using the 2.8 VM Motori diesel for a swap. Some recommended the 4bt which I still don't understand why anyone would want the fat pig in one of these trucks. It weighs half a ton and vibrates enough to please the woman on Colfax.
    Some recommended the tdi which I had kind of wrote off because it doesn't make a whole lot of power stock but I guess with a tune and some other things they are pretty easy to get to 200hp and over 300ftlbs of torque. The company ACME makes a bellhousing that fits my w59 trans so that's also a plus. Not sure how long it would last though with that much torque.
    Rebuilding my current motor is still probably the most likely option to occur though.
    jubei likes this.
  10. Sep 16, 2017 at 7:58 PM
    #470
    Reh5108
    Idaho
  11. Sep 23, 2017 at 5:34 PM
    #471
    Reh5108
    Idaho
    So driving home tonight I thought to myself, I wonder if altitude effects compression. A quick Google search and sure enough it does! So from what I'm seeing is that I'm at about 23%less compression than if I was at sea level. So if I was at sea level my compression of 110psi would be around 135psi. 135psi is within the acceptable range!
    When I did a wet test it was 150psi which factoring for altitude would be 185psi which is what it would be brand new. So it looks like my rings are worn a little but my valves are fine.
    Finding this out gives me some piece of mind that my motor isn't in as rough of a condition as I had thought. I still want more power. It gets old having to drop to 3rd just to maintain the speed limit during my commute to work.
  12. Sep 23, 2017 at 7:37 PM
    #472
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I think I saw you around 5/5:30 headed north / west on 40 in the opposite direction.
  13. Sep 23, 2017 at 8:38 PM
    #473
    Reh5108
    Idaho
    Haha I didn't even think of that being you! I was headed home from work. What brought you up this way?
  14. Sep 24, 2017 at 6:23 AM
    #474
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    I did some hiking at RMNP and then played around Stillwater pass area on the way back for some leaf peeping. Not the best day for it but at least the rain washed my truck.
    Reh5108[QUOTED][OP] likes this.
  15. Sep 27, 2017 at 9:10 AM
    #475
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Heard rumors of diesel swappage :popcorn:
  16. Sep 27, 2017 at 1:06 PM
    #476
    Reh5108
    Idaho
    Possibly. I've been reading a lot and the easy swaps are all done with pretty weak motors. The Mercedes Om617 has an adapter kit with everything I need except motor mounts but if I can't get more than 150 ponies from it I doubt it's worth it. It is an all mechanical motor and has quite the reputation for reliability.
    The tdi swap also has kits but I'm seeing people complain of alignment issues with the throwout bearing/bushing. The 2.0 tdi make 140hp but need the timing chain replaced with a gear driven setup. (there might have been a recall for it so most may have had it done) Also the camshaft has a terrible geometry and destroys itself and the rockers. So that would need to be replaced as well.
    Still lots of researching before committing to this swap. It would be amazing to just let the clutch out and have lots of torque to crawl.
  17. Sep 27, 2017 at 5:44 PM
    #477
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Absolutely that's how everything I drive/own is besides the tacoma. I started poking around the subject but you've obviously done a little more research
  18. Sep 27, 2017 at 7:26 PM
    #478
    Reh5108
    Idaho
    @jubei apparently my air locker compressor heard me talking other options earlier. Just randomly thought I'd flip it on annnndddd nothing! Lol Hopefully it's just a bad connection.
    jubei likes this.
  19. Sep 27, 2017 at 7:42 PM
    #479
    jubei
    NoCo
    Stuff. Also things.
    :rofl::rofl::rofl:
  20. Sep 27, 2017 at 7:43 PM
    #480
    jubei
    NoCo
    Stuff. Also things.
    In all seriousness, I hope that thing is ok!
