reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Dec 9, 2017 at 7:01 PM
    #541
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    So in the 03 fsm I have it says to torque the flywheel bolts to 19ftlbs and doesn't mention anything about replacing them. The 3rz manual I have says to replace them, torque to 19ftlbs then another 90°. I think I'll go with the latter, now I'll be waiting on bolts and hopefully I can find a competent shop locally that can resurface my flywheel. Marlin recommends .026 stepping.
    ChadsPride, jubei and Dalandser like this.
  2. Dec 9, 2017 at 7:02 PM
    #542
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @Speedytech7
    Y'all are lucky - I had to get them to 61 lb-ft for the 5vz which was not going to be fun alone since I couldn't find anything to keep the flywheel from turning with - luckily my friend was helping and we could muscle it together.
  3. Dec 9, 2017 at 7:09 PM
    #543
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yes do a couple rounds of 19ft lb (I just did 20 because it was easier to dial in) in a cross-starlike pattern to make sure it is being seated absolutely flat. Very important, after than find a friend to hold the crank from turning with a breaker bar and do the additional 90 degrees, again in in a cross pattern. The bolts are stretch bolts so don't reuse your old ones, that is asking for major failure. The elasticity of that last 90 degrees is paramount to keeping the flywheel in place, I used OEM bolts which come preapplied with thread locker. There are ten of the little bastards so mark them after you do your 90 degree step so you don't forget which have been done. I used a new flywheel so I can't tell you what you should grind yours to. @Reh5108
  4. Dec 9, 2017 at 7:24 PM
    #544
    Reh5108
    Idaho
    Thanks! I might borrow a dial indicator from work just to make sure that there is no runout when I reinstall. Probably not necessary but it can't hurt.
    ChadsPride and Dalandser like this.
  5. Dec 9, 2017 at 7:33 PM
    #545
    Reh5108
    Idaho
    @Speedytech7 how critical is it to reinstall the flywheel the same way it came off? I didn't think to mark it.
    ChadsPride likes this.
  6. Dec 9, 2017 at 7:35 PM
    #546
    Speedytech7
    Not even slightly, they aren't balanced as a pair. Install as you please
  7. Dec 9, 2017 at 7:38 PM
    #547
    Reh5108
    Idaho
    Good to hear
  8. Dec 14, 2017 at 7:14 AM
    #548
    Reh5108
    Idaho
    My diff is on the way back from ECGS. They said there was a seal that needed replaced. There customer service has been top notch. There were some issues in the shipping department but they were happy to get it sorted out. I sent it out the 7th and should have it back by the 16th. Pretty good turn around time in my opinion.
    Also I got an offer on the car that I can't pass up so the truck will be back to DD duties until I can find a beater. Then rebuilding the motor.
  9. Dec 19, 2017 at 6:36 PM
    #549
    Reh5108
    Idaho
    Truck is back on the road. Clutch honestly feels the same other than the pedal being buttery smooth and almost too easy to push.
    The ARB seems to be sealing up but I won't really know until I use it. The whole warranty process with ECGS went very smooth. Not a penny out of my pocket.
    Next project will be new springs. Then pulling the bed off, fixing my gas tank, boxing the frame and some sort of shock relocate.
    I haven't heard from the guy who wanted to buy the car in a few days so I might be hanging onto it for a while.
    jubei and Squeaky Penguin like this.
  10. Dec 20, 2017 at 4:25 AM
    #550
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    What clutch did you go with? I’m sure you said it but I don’t feel like looking :anonymous:
  11. Dec 20, 2017 at 6:11 AM
    #551
    Reh5108
    Idaho
    The Marlin 1200lb pressure plate one. It feels lighter than what I had but that could be because of the throwout bearing being bad. I want to look up the part number of the old pressure plate and see if that was the stock 900lb. Also i had the flywheel resurfaced with the step at .025 instead of oem spec of .02. It changed where it engages slightly but not by too much.
  12. Dec 20, 2017 at 6:39 AM
    #552
    cynicalrider
    cynicalrider #NFG
    Jersey
    My biggest thing I noticed with mine was that it felt so much "grabbier", like I could really pinpoint engagement.
  13. Dec 26, 2017 at 2:51 PM
    #553
    Reh5108
    Idaho
    Replaced my steering rack billow today and while I had that wheel in the air I checked the lbj. It already has a very small amount of play. Looks like I might go through a pair a year or LT
  14. Dec 26, 2017 at 2:59 PM
    #554
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    Didn't you just replace your LBJs before RT?
  15. Dec 26, 2017 at 4:40 PM
    #555
    Reh5108
    Idaho
    Yep. Probably not even 2000 miles on them
  16. Dec 26, 2017 at 8:53 PM
    #556
    Tacofire98
    Jake
    Castle Rock
    01 TRD
    dang dude, your doing OEM too aren't you?
  17. Dec 27, 2017 at 6:44 AM
    #557
    Reh5108
    Idaho
    Yep. Id say its close to the oem maximum spec of 0.5mm of play. I dont have a dial indicator to check though.
  18. Dec 27, 2017 at 10:34 AM
    #558
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I wonder if there's something else going on? I put new OEM ball joints in spring of 15, so they have 3 hard wheeling seasons on them, and they're still fine last I checked.
  19. Dec 27, 2017 at 2:41 PM
    #559
    Reh5108
    Idaho
    I've wondered the same thing. Just cant think what it would be.
  20. Dec 27, 2017 at 7:39 PM
    #560
    Squeaky Penguin
    Brett
    The only thing that I would think would cause those to fail prematurely is overextending the joint.
    What I wonder about is those SPC arms. With their big ball joint increasing the height between the spindle and UCA, the UCA is at a different angle than stock. Probably the same reason you smash the zerks through the fender. This would introduce bump steer, and put the spindle at a steeper angle at full bump. Just a completely guess.
    Ever cycle the front without the shock? You're definitely not over-extended them on downtravel with your OMEs.
