reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Jul 21, 2018 at 6:54 PM
    #761
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    No worries, the jb water weld seems to be holding fine. I just have a high clearance tank right now.:D
    SilverGhost[QUOTED] likes this.
  2. Jul 21, 2018 at 7:22 PM
    #762
    Reh5108
    Idaho
  3. Jul 21, 2018 at 10:10 PM
    #763
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    Really wish could have joined you guys!
    Reh5108[OP] likes this.
  4. Aug 16, 2018 at 1:04 PM
    #764
    Reh5108
    Idaho
    Finally got around to running Black Bear Pass and Imogene Pass. Honestly thought Imogene was the better of the two. Then we headed to Engineer Pass to hop on Poughkeepsie Gulch and about 100yds in, my clutch pedal goes to the floor. So I clutch start cancel to get rolling to a point where we can pull off and take a look. My compressor which was half asses mounted near the master cylinder had wore a tiny pine hole in the line connecting the master to the slave. It was getting close to the time the shops in Ouray would be closing so I quickly cleaned up the line and tried to patch it with quick steel and let it cure while we headed to town to get brake fluid since the bottle I carry seemed to have all leaked out. 45 min later we get back to the truck and being pretty confident that the quick steel would hold we mosied up the trail to find camp for the night and then I'd check to see if the quick steel held. Once we had camp I poured in some fluid and pushed the clutch pedal only to have a little resistance then nothing again. So back to square one. Let's try some JB weld and let it cure overnight.
    Morning comes I start the process of bleeding the clutch and all seems well so we decide to continue on with Poughkeepsie Gulch. We'll there was a jeep in front of us that stopped in the middle of a steep loose rocky climb, so I went to push the clutch pedal and had nothing again. So now I'm stuck on this hill not able to start the truck going forward and a herd of Jeeps coming behind us. Fortunately I was able to back down to a less steep spot and the truck finally fired so I could continue climbing the hill. I found a spot to pull off the trail, let the herd go and turn around back to Ouray.
    Made a few calls to Montrose and Durango part stores to see if I could get lucky and continue my trip. Unfortunately the earliest I could get a line was Thursday, the last day of the trip, when I needed to be on the way home. So I decided to just rev match and drive home. Really wasn't all that bad other than the red lights in Montrose.
    So moral of the story JB weld doesn't fix everything and bolt down your compressor :spy:
    Bummed I didn't get to finish Poughkeepsie and continue on to Stony Pass and then Pearl Pass. I'll just have to schedule another trip.
    20180813_115724 by Ryan Heintzelman - Flickr2BBcode
    20180813_131102 by Ryan Heintzelman - Flickr2BBcode
  5. Aug 17, 2018 at 5:30 PM
    #765
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yikes. Always something.
    Reh5108[QUOTED][OP] likes this.
  6. Aug 17, 2018 at 5:31 PM
    #766
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Worth getting back down and doing the rest of the planned trip though
  7. Aug 19, 2018 at 5:01 AM
    #767
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's crazy, and pretty damn scary. Glad you made it off okay.
  8. Aug 20, 2018 at 7:09 PM
    #768
    Reh5108
    Idaho
    Well, went to jack up the front so had more clearance to access the clutch line and noticed my tire move once it left the ground. Front wheel bearings are toast! I'm guessing this was caused by the flood. I don't think I have more than 60k on them. Time for gussets and bushings in the front end while it's ripped apart.
    SilverGhost likes this.
  9. Aug 21, 2018 at 4:39 AM
    #769
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    As I previously stated... your rig is the gift that keeps on giving. :oops:
    SilverGhost and Reh5108[OP] like this.
  10. Aug 21, 2018 at 6:06 AM
    #770
    cynicalrider
    cynicalrider #NFG
    Jersey
    You think that was caused by water? It's not like you haven't done like hundreds of crossings, regardless of sitting in it or not. Seems odd to be the cause.
  11. Aug 21, 2018 at 1:30 PM
    #771
    Reh5108
    Idaho
    I think sitting in in makes a big difference as opposed to driving through it. Last time I did them was the day after having it swamped in muddy water. Somehow avoided flooding the cab that time but I was still over the hood when I dropped in and had to winch out. Maybe it's coincidence that shortly after I've had the truck sitting in water the bearings go out but I doubt it. I should probably jack up the rears and check them too or maybe I'll go with ignorance is bliss on those!
  12. Aug 21, 2018 at 1:38 PM
    #772
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Hope you can get this thing to a place where you can wheel it and not have to fix it every trip. I know how frustrating that is.
    Also have new, OEM 01-04 rear wheel bearings on the shelf I ordered before knowing they wouldn't work with the chromoly shafts. Yours if you want them.
  13. Aug 22, 2018 at 7:52 AM
    #773
    Reh5108
    Idaho
    I'll let you know. Probably going to be a week or so until the front is back on the ground to check the rears.
    Got one LCA out last night. Just need to pull the cam bolts for the other. So far things are going pretty smoothly. I've read the whiteline bushing sleeve isn't splined on the end for the cam. Should I swap those out with the oem sleeve?
    Hoping to have it back on its wheels for a road trip to Arkansas on the 3rd.
  14. Aug 22, 2018 at 9:01 AM
    #774
    Squeaky Penguin
    Brett
    I've had zero issues holding an alignment with the whitelines and TC gussets.
    I wouldn't bother.
    jubei and Reh5108[QUOTED][OP] like this.
  15. Sep 5, 2018 at 1:05 PM
    #775
    Reh5108
    Idaho
    Some random pics from cam tab gussets, lca bushing, lower shock eye bushing. Also did spindle gussets but didn't take any pictures of it. The worst part of all of this was reinstalling the LCA. Getting the washers in was a huge pita. Second worse was the lower shock bushing. That thing is a tight fit! Both getting it out and installing a new one sucked.
    With the new to me spindles I now have camber adjustment again on the driver side. I presume my old spindle was bent. My passenger side is still maxed out for camber adjustment but it's still within spec.
    Overall this wasn't as difficult of a project as I thought it would be.
    20180824_191057 by Ryan Heintzelman - Flickr2BBcode
    20180823_194003 by Ryan Heintzelman - Flickr2BBcode
    20180823_203607 by Ryan Heintzelman - Flickr2BBcode
    20180824_143045 by Ryan Heintzelman - Flickr2BBcode
    20180830_202028 by Ryan Heintzelman - Flickr2BBcode
    20180904_130101 by Ryan Heintzelman - Flickr2BBcode
  16. Sep 5, 2018 at 5:33 PM
    #776
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Nicely done. Them bitches are not going anywhere.
  17. Sep 6, 2018 at 9:30 AM
    #777
    alee891
    Austin
    Black Hills
    Tacomaless
    Tinder appears to be a valuable helper while your wrenching!
  18. Sep 6, 2018 at 10:55 AM
    #778
    Reh5108
    Idaho
    He's really the brains behind it all...
    Wishbone Runner likes this.
  19. Sep 10, 2018 at 8:40 PM
    #779
    Reh5108
    Idaho
    Back from a 2000+ mile trip to Arkansas for my roommates wedding without any major hiccups. Pretty sure my power steering pump is whining, hopefully it's just a dirty screen but I doubt it. Also the oversized oil plug is leaking a bit, lost about an 1/8th inch on the dipstick throughout the trip. I have a new pan along with some other goodies :spy: that should be here by the end of the week. :burnrubber:
  20. Sep 11, 2018 at 6:13 PM
    #780
    Reh5108
    Idaho
    I forgot that the last two times filling with gas the pump kept shutting off almost immediately. I'm guessing I've got a clog in my evap system somewhere.
