reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Sep 11, 2018 at 8:37 PM
    #781
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
  2. Sep 12, 2018 at 4:39 AM
    #782
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Man you can’t catch a break from things going wrong.
    Reh5108[OP] likes this.
  3. Sep 12, 2018 at 4:44 AM
    #783
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Probably a leaking rear trans seal. I’d split the case a touch and make sure the cavity between the trans and tcase isn’t full of fluid. It’d suck to lunch a trans by pumping all the fluid out the rear seal.
    ToyRyd04 and Reh5108[QUOTED][OP] like this.
  4. Sep 12, 2018 at 9:28 AM
    #784
    Reh5108
    Idaho
    What I was thinking. Going to check trans fluid level tonight and clean it up just to make sure that's where it's coming from.
  5. Sep 12, 2018 at 5:36 PM
    #785
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    This. My truck had a defective/damaged seal from the factory. The trans lasted 4300 miles. Took it back to the dealer and they found the trans empty and the piece between the trans and transfercase full of oil.
  6. Sep 13, 2018 at 7:19 PM
    #786
    Reh5108
    Idaho
    Yep, definitely leaking from between the two. Open both fill holes and had oil running out so it's not too bad yet. Hoping to get a trip in next weekend then after that tear it apart.
    20180912_201438 by Ryan Heintzelman - Flickr2BBcode
    Started replacing leaf spring bushing on the T100 and noticed how much beefier the frame is. Boxed all the way to the rear and the crossmembers are twice as thick. Wish the Taco came that way. Might have to throw the Toytec adjustable shackles in it since the metal on metal looks like it's worn the lower bolt quite a bit. It's gonna have a lot of take if I do that but O well. Might be able to crank the torsion bars in the front up some to even it out. :notsure:
    jubei likes this.
  7. Sep 17, 2018 at 4:35 PM
    #787
    Reh5108
    Idaho
  8. Sep 17, 2018 at 4:40 PM
    #788
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
  9. Sep 17, 2018 at 4:42 PM
    #789
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
  10. Sep 23, 2018 at 7:49 PM
    #790
    Reh5108
    Idaho
    Edited title to more accurately describe this build...
  11. Sep 23, 2018 at 8:13 PM
    #791
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Ryan always goes the extra mile to get the shot.
    Sucks about your rig! Hopefully you can get everything sorted and get it solid.
  12. Sep 24, 2018 at 1:44 PM
    #792
    Reh5108
    Idaho
    So my cvj reman rack died yesterday on the final climb up Taylor Pass. Fluid just pisses out the passenger side boot. Probably burnt up the pump as well.
    Front locker ratchets more than locks now.
    Lots of big maintenance things this winter which will unfortunately push back the turbo install. Idk if my pockets will allow me to keep fixing this shitbox
  13. Sep 24, 2018 at 1:44 PM
    #793
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Did you buy a turbski?
    Reh5108[QUOTED][OP] likes this.
  14. Sep 24, 2018 at 2:09 PM
    #794
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah I just spent 850.00 on a rack and pump. Brett found a good deal on a pump. Hopefully that will help a little.
  15. Sep 24, 2018 at 2:09 PM
    #795
    Squeaky Penguin
    Brett
    Park it for a couple months and then reevaluate.
    I was ready to sell my rig too a year ago, but not having to worry about it until next season gives you time to sort things out and forget your frustrations.
    Oh, and don't buy a Jeep. :D
  16. Sep 24, 2018 at 2:53 PM
    #796
    jubei
    NoCo
    Stuff. Also things.
    Sorry to hear about the continuing struggles wth your rig, Ryan. That’s gotta be super frustrating.
  17. Sep 24, 2018 at 3:06 PM
    #797
    Reh5108
    Idaho
    Yep, was planning on installing it next month but I think it's best I fix my current problems before I create new ones.
  18. Sep 24, 2018 at 3:12 PM
    #798
    Speedytech7
    Yeah that's wise, your gonna get yourself into a whole new world of things to learn and tune and tweak with a turbo.
  19. Sep 25, 2018 at 5:02 AM
    #799
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Oh I hear ya bud, I was super excited to finally get the truck running after getting the cage welded and thinking, Sweet! I can start the rear. But my steering started stiffing up. I knew it was due but I really wanted to get the links cut and order the fuel cell with that cash. It takes the wind out of your sail real quick. I just think to myself all in good time, just roll with the punches. Any how good luck on the repairs and hopefully they go smoothly. :thumbsup:
  20. Oct 15, 2018 at 8:35 PM
    #800
    Reh5108
    Idaho
    Started pulling my steering rack apart today. Once I remove the control valve the bearing guide nut practically fell off the shaft. I'm not sure if this was my problem or if it's the seal in the cylinder. I haven't removed the cylinder yet since the fsm recommends using a press and I'd rather not hammer something and damage it. I've also noticed a severe lack of molybdenum grease on parts the fsm calls for.
    Picture of the loose nut.
    20181015_140910 by Ryan Heintzelman - Flickr2BBcode
    Pretty good video on how a rack works. The control valve is a pretty interesting part.
    https://youtu.be/amTnNkAhWgQ
    SilverGhost and Speedytech7 like this.
