reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Dec 22, 2018 at 7:39 PM
    #821
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Drove it to work today and I've got to say there is just something about the Tacoma that is just fun. Filled it up with gas for the first time since replacing the charcoal canister and had no issues with the pump shutting off. One small step in this thing becoming less of a shitbox.
  2. Dec 23, 2018 at 7:28 AM
    #822
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Dang. Eff my theory then lol
  3. Dec 23, 2018 at 7:50 AM
    #823
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No more 10 minute fill ups? :p
    Did you put the front diff back in already?
  4. Dec 23, 2018 at 2:53 PM
    #824
    Reh5108
    Idaho
    Nope, driving without it. Have some cv stubs keeping tension on the bearing. Probably won't go back in until I have the turbo dialed in. Easier to work without that chunk in there.
  5. Dec 23, 2018 at 5:07 PM
    #825
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    Reh5108’s 4banging shitbox temporary prerunner buildo_O
    Reh5108[QUOTED][OP] likes this.
  6. Dec 30, 2018 at 9:00 PM
    #826
    Reh5108
    Idaho
    Found a crack in the T100 radiator. Decided to be a cheap ass and try and fix it with jb welds radiator repair. Haven't driven it yet but hopefully it holds for awhile.
    20181228_193544 by Ryan Heintzelman - Flickr2BBcode
    20181230_083533 by Ryan Heintzelman - Flickr2BBcode
    Drove the Tacoma all the way to Denver today to Sears in hopes of getting my battery replaced. Only to have them tell me 770 out of the 850cca is still good. Mind you that was tested at 55ish degrees not the 0 CCA are measured at. The truck won't even turn over in the morning after sitting outside with temps around 0. Frustrated I made the drive to be told to call the manager tomorrow. :mad:
  7. Jan 2, 2019 at 9:04 AM
    #827
    Reh5108
    Idaho
    Well jb welds radiator fix didn't work on the T100 Had the truck sit in a 55° garage for 3 days, thought that would have been long enough to cure. It was -20° this morning so its possible the extreme cold to the warmth of the the coolant caused it to fail. Truck absolutely does not want to move when it's that cold. Top speed is around 50mph until things warm up.
    I'm pretty sure the whine I'm hearing in the Tacoma is the fuel pump. Sounds identical to the power steering pump whine but it still did it when that was all disconnected. Seems to stop whining when I let off the throttle too. Time for an upgrade.
  8. Jan 20, 2019 at 7:24 PM
    #828
    Reh5108
    Idaho
    Got started on the turbo project!
    Pulled the old pan off. I found a little bit of sludge but nothing terrible. Hopeful putting the turbo pan on tomorrow after the oil is done dripping everywhere.
    20190120_155123 by Ryan Heintzelman - Flickr2BBcode
    So far I've got 2 problems to overcome. The wastegate is all but pinching the AC line between the fender. Need to find another airbox that's compatible with the snorkel.
    Debating if I want to run this intercooler or clock the turbo and go straight to the throttle body for now.
    20190120_175209 by Ryan Heintzelman - Flickr2BBcode
    20190120_175231 by Ryan Heintzelman - Flickr2BBcode
    20190120_175739 by Ryan Heintzelman - Flickr2BBcode
    20190120_190637 by Ryan Heintzelman - Flickr2BBcode
    Wishbone Runner, jubei and SwampYota like this.
  9. Jan 20, 2019 at 7:27 PM
    #829
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    2014 TDR Off Road
    Enough to make it a lot of fun!
    If you want to build an air box out or sheet metal I can bend it with my break at work.
  10. Jan 20, 2019 at 7:39 PM
    #830
    Reh5108
    Idaho
    I hope it doesn't come to that but I'll keep that in mind.
  11. Jan 20, 2019 at 7:52 PM
    #831
    Reh5108
    Idaho
    Anyone know of any vehicle with an airbox where the inlet and outlet are directly across from one another?
  12. Jan 24, 2019 at 6:59 PM
    #832
    Reh5108
    Idaho
    Did some Non Destructive Testing on my ring gear. No cracks were found!
    20190124_141920 by Ryan Heintzelman - Flickr2BBcode
    Still not sure why my locker wasn't working 100%. Everything is within spec. There is a very small amount of wear on the cam gear and pin so I think I'm going to replace those and hope for the best. I also learned that some 1st gen carriers don't have a needle bearing.
    20181229_183822 by Ryan Heintzelman - Flickr2BBcode
    20181229_183936 by Ryan Heintzelman - Flickr2BBcode
    20190113_144414 by Ryan Heintzelman - Flickr2BBcode
    20190113_144509 by Ryan Heintzelman - Flickr2BBcode
    ToyRyd04 and Wishbone Runner like this.
  13. Jan 24, 2019 at 9:40 PM
    #833
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Damn, you got balls deep in that.
  14. Jan 25, 2019 at 5:01 AM
    #834
    Reh5108
    Idaho
    I really don't want to pull the diff again.
    rngr and Wishbone Runner[QUOTED] like this.
  15. Jan 30, 2019 at 3:52 PM
    #835
    Reh5108
    Idaho
    Wishbone Runner and jubei like this.
  16. Jan 30, 2019 at 3:59 PM
    #836
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Looking good, Ryan.
    How’d you break your foot?
  17. Jan 30, 2019 at 6:48 PM
    #837
    cynicalrider
    cynicalrider #NFG
    Jersey
    Something tells me he sled necked too hard.
    Reh5108[OP] likes this.
  18. Jan 30, 2019 at 7:09 PM
    #838
    Squeaky Penguin
    Brett
    Needs a top mount with a hood skewp. :cookiemonster:
  19. Jan 30, 2019 at 8:22 PM
    #839
    Reh5108
    Idaho
  20. Feb 9, 2019 at 7:29 PM
    #840
    Reh5108
    Idaho
    Hobbled into the garage after laying in bed watching KOH all week. Cool watching a leaf spring Toyota pickup win the stock class.
    Got the oil feed line installed. It's a tight fit with the block drain being right there. I believe some 3rz's come with just a plug which would have allowed plenty of room but I wanted to keep the drain pipe for ease and less of a mess when I do need to drain it. Also wrapped the AC line in heat reflective tape. I think it's out of the way enough with the fender massaging and bending the hard line. Hopefully going to get the manifold bolted in tomorrow and figure out the rest of the hose plumbing.
    20190209_173905 by Ryan Heintzelman - Flickr2BBcode
    20190209_173912 by Ryan Heintzelman - Flickr2BBcode
