reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Feb 19, 2019 at 6:48 PM
    #861
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Reh5108[QUOTED][OP] likes this.
  2. Feb 19, 2019 at 7:09 PM
    #862
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Ah, thought you had a 50 also. Hopefully the turbo changes my note. If not I might have to go with a 40 at some point.
  3. Feb 19, 2019 at 7:55 PM
    #863
    Night Eagle
    Night Eagle Aka Mountain Goat or mr. Clean
    Leo
    Steamboat Springs, Co
    2014 TDR Off Road
    Enough to make it a lot of fun!
    So you can drive it to steamboat this weekend, so we can tear Brett's truck apart.
  4. Feb 19, 2019 at 8:28 PM
    #864
    Reh5108
    Idaho
    I mean I drove from Ouray home with no clutch over the summer. The red lights are the annoying part.
    I could also drive the T100 which is auto but what fun is that.
    Night Eagle[QUOTED] likes this.
  5. Feb 19, 2019 at 9:14 PM
    #865
    Night Eagle
    Leo
    2014 TDR Off Road
    hey as they say you only live once.
  6. Feb 20, 2019 at 7:35 AM
    #866
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    The 40 series and super 44 definitly have a deeper tone than your truck. Mine sounds pretty good with a 44 and I bumped up to 2.5” pipe aswell. I’ll up load a video later if you’d like
  7. Feb 20, 2019 at 10:17 AM
    #867
    Reh5108
    Idaho
    Not too worried about it, I remember being impressed with how yours sounded. At some point I'll likely redo mine to allow for better flow. The 45° tube I used wasn't mandrel bent so its probably building some unnecessary backpressure.
  8. Feb 20, 2019 at 6:10 PM
    #868
    Wheelspinner
    Northern NJ
    '13 4x4x4cyl
    What are you gonna be doing about a tune to make up for the extra air?
  9. Feb 20, 2019 at 6:54 PM
    #869
    Reh5108
    Idaho
    Nothing for now. From reading other builds the stock ecu can account for 5-6psi. The previous owner was running 8psi with the intercooler installed.
    Wheelspinner[QUOTED] likes this.
  10. Feb 21, 2019 at 6:53 AM
    #870
    cynicalrider
    cynicalrider #NFG
    Jersey
    Damn that's a cool little mod.
  11. Feb 24, 2019 at 1:48 PM
    #871
    Reh5108
    Idaho
    Little update on the truck. On start up I was hearing a rattle right around idle that had me a little bit worried. Using a trusty screw drive and put my ear to it and poked around. I found the noise was coming from the wastegate.
    https://youtu.be/5QAjKpGi2T4
    Here's the culprit.
    https://youtu.be/p8-KFfFVDn4
    Thanks to @Torspd for pointing out that the valve wouldn't seal and let exhaust gas by. I looked at the part diagram and found that I forgot to install the valve seat! Oops!
    20190222_091028 by Ryan Heintzelman - Flickr2BBcode
    20190222_091039 by Ryan Heintzelman - Flickr2BBcode
    Once that was sorted out I took it for a drive around the neighborhood. Being that everything is snow packed and I'm 2wd at the moment it's tough to actually get into boost because I just spin tires, it definitely feels like it pulls better though. Pulled back into the garage and noticed the turbo was leaking oil.
    20190222_163713 by Ryan Heintzelman - Flickr2BBcode
    I believe this was caused by my pcv still being routed into the intake. With positive pressure holding the valve shut and blow by getting past the cylinders I was pressuring the oil pan which wasn't allowing the oil to flow down the return line and finding the next easiest way out, through the turbo. I plugged the intake port the pvc fed and vented the pcv to atmosphere for now. Took it for a short drive and I think I'm oil free!
  12. Feb 24, 2019 at 10:19 PM
    #872
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Glad you got that oil leak sorted. Now for the roads to clear, for some real fun!
    Reh5108[OP] likes this.
  13. Feb 24, 2019 at 10:50 PM
    #873
    Reh5108
    Idaho
    Really, it's more my broken foot keeping me off the busy roads which are free of snow. Clutching with the right foot and using the ebrake to slow is a mind fuck lol.
  14. Feb 25, 2019 at 6:00 AM
    #874
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They don't teach that in driver's ed.
  15. Feb 25, 2019 at 11:00 AM
    #875
    Reh5108
    Idaho
    Short pull... https://youtu.be/qrlngK3pjN8
    It's pretty responsive, 5th gear is now usable again. I didn't do any real big hills but I'd usually have to downshift to fourth on some small grades on the route I took. If I can make it up the hill just south of me in fourth doing 65 MPH I'll be satisfied for now.
    I have an exhaust leak. I think it's right where the manifold bolts on. I'm not sure if I still have a small oil leak or if it is just stuff burning off the wrap and turbo blanket.
    I'm also not entirely sure that my ecu is compensating for the extra air. My afr never dropped below 14 even when I hit open loop at 5psi.
  16. Feb 28, 2019 at 8:12 PM
    #876
    Reh5108
    Idaho
    Decided to do the MarMount mod on the driver side motor mount. I'm glad I did. There wasn't much life left in the mount and it had began to separate.
    20190228_165419 by Ryan Heintzelman - Flickr2BBcode
    It's basically just cutting that stud off and drilling a hole the whole way though. I used a M12 x 90mm bolt an 80mm would be perfect, 90 is a little long. Now when the motor trys to rotate its trying to stretch the bolt instead of the worn out rubber.
    20190228_164854 by Ryan Heintzelman - Flickr2BBcode
    Added a neoprene washer on both sides as you will feel some more engine vibes. I haven't driven the truck yet but started it up and it's noticeable at idle. Anxious to see how @Squeaky Penguin HD mounts feel in comparison.
    20190228_183052 by Ryan Heintzelman - Flickr2BBcode
    Crappy pic but you get the idea. I don't think this would be possible to do with the differential in there. So something to think about if you ever have yours out.
    20190228_183713 by Ryan Heintzelman - Flickr2BBcode
    I'm still dealing with oil leaking out of the turbo. I'm almost to the point of thinking that it is actually the turbo itself and not excessive crank pressure. I don't think I have anything that could possibly be blocking the oil return but it's the next thing to check before ordering new turbo seals.
    Hopefully I fixed the exhaust leak. Found it was coming from the egr flange. Smothered the gasket in copper rtv. Hopefully it works...
    20190228_202832 by Ryan Heintzelman - Flickr2BBcode
  17. Feb 28, 2019 at 8:17 PM
    #877
    Night Eagle
    Leo
    2014 TDR Off Road
    Brett's motor mounts looked the same way when we started to mess with the mounts.
  18. Mar 12, 2019 at 10:25 AM
    #878
    Reh5108
    Idaho
    I've put about 75 miles on the turbo. I'm loving how quite the truck is! I never knew my tires made a sound before!
    My AFRs aren't dropping as low as I'd hoped when in open loop. Only hitting 13.7. I'm hoping it's just because of my fuel pump having 250k on it. Should have a new one this week. Hopefully I can also figure out why my sending unit doesn't read below a quarter tank.
  19. Mar 12, 2019 at 11:31 AM
    #879
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your truck has an external fuel filter correct?
    Has that been changed recently? If not, good do do with the pump.
    Decided which pump you are going to use?
  20. Mar 12, 2019 at 11:37 AM
    #880
    Reh5108
    Idaho
    The filter has maybe 10k on it. It's under the intake manifold. Went with the Walbro 190
    Torspd[QUOTED] likes this.
