reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Mar 14, 2019 at 8:50 PM
    #881
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I went with the same pump. I didn't notice the walbro noise everyone talks about. Hopefully it's quite for you too bud.
    Reh5108[QUOTED][OP] likes this.
  2. Mar 16, 2019 at 5:26 PM
    #882
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Front diff is back in! I hope I don't have to wrastle with doing that again in a long time.
  3. Mar 20, 2019 at 9:55 PM
    #883
    Reh5108
    Idaho
    I think I've got all the kinks out of the turbo. Installed the plx boost and afr module behind the kick panel. Using there multiguage app to view readings. The app can be a pita to connect for some reason at times. I'm hoping plx continues to build upon it. Being able to data log would be nice and more sensor support.
    20190320_163140 by Ryan Heintzelman - Flickr2BBcode
    20190320_195820 by Ryan Heintzelman - Flickr2BBcode
    20190320_192253 by Ryan Heintzelman - Flickr2BBcode
    The truck is slowly getting faster!
    Stock
    20170410_194341 by Ryan Heintzelman - Flickr2BBcode
    LCE header
    20170516_135034 by Ryan Heintzelman - Flickr2BBcode
    4.5psi boost. Slightly uphill. I'll have to do the same pull as the stock and header ones were done at but it's much improved!
    20190320_205029 by Ryan Heintzelman - Flickr2BBcode
    Still having locker issues though. I must have some splines stripped somewhere that I overlooked when I had it disassembled. :frusty:
    jubei likes this.
  4. Mar 22, 2019 at 4:07 PM
    #884
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Turbo? What the fawk have I missed in here?
    jubei and Reh5108[OP] like this.
  5. Mar 22, 2019 at 4:18 PM
    #885
    Reh5108
    Idaho
    Mostly problems.
  6. Mar 22, 2019 at 9:25 PM
    #886
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    And everything else. Lol. Catch-up buddy!!!
    Reh5108[OP] likes this.
  7. Mar 23, 2019 at 8:09 PM
    #887
    Reh5108
    Idaho
    Success! What I thought was my locker ratcheting was actually the chain in the tcase. Glad that's over with. Hopefully no leaks coming from the used case now.
    Change trans fluid, install skids, diy alignment and hopefully that's all it needs until next year.
  8. Mar 23, 2019 at 8:11 PM
    #888
    Reh5108
    Idaho
    And if you're ever bored sometime try hopping on one foot with a transfer case in your hands to the other side of the the garage.
    HomerTaco likes this.
  9. Mar 23, 2019 at 8:14 PM
    #889
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's quite the mental imagery there... :D
  10. Mar 23, 2019 at 8:28 PM
    #890
    Reh5108
    Idaho
    Sounds like you have a good opportunity to try coming up :D
  11. Mar 23, 2019 at 8:33 PM
    #891
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I need to get back out your way again... I really miss @Littles - he's my little brother form another mother.
    Maybe next year. :pray:
  12. Mar 23, 2019 at 8:35 PM
    #892
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Glad you got it sorted! :thumbsup:
    Wonder if the auto locker has anything to do with the transfer case failure? I've heard of them failing, but doesn't seem too common.
  13. Mar 23, 2019 at 8:38 PM
    #893
    Reh5108
    Idaho
    I have a wedding to attend in WV in fall of 2020. I'd like to make it back to Rausch and check AOAA out. I'll post in the PA thread and see what everyone is up to when it gets closer.
    HomerTaco[QUOTED] likes this.
  14. Mar 23, 2019 at 8:42 PM
    #894
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Let me know. We’ll make it happen. :cool:
  15. Mar 23, 2019 at 8:42 PM
    #895
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I didn't recommend this... But if you wanna test your fuel pump theory, even though it's great practice to put a higher flow one in anyway. You can put a line clamp on the return hose from the FPR to raise the pressure a bit, or if your pump sucks itll fall on it's face.
  16. Mar 23, 2019 at 8:44 PM
    #896
    Reh5108
    Idaho
    I did think about that. The open rear is really the only place that can account for different speeds when in 4x4. Thought about running 80-140 in it but stuck with 75-90. The oil was rancid, I didn't think I got water in when I flooded it but after draining it I'm almost certain I did.
  17. Mar 23, 2019 at 8:55 PM
    #897
    Reh5108
    Idaho
    I'm pretty sure it was starting to wine when it was under heavy load. Sounded similar to an unhappy power steering pump but it was coming from the rear of the cab.
    I'm still only hitting an afr of 13 in OL. When I first installed the pump I hit 12. I pulled the pump because I randomly wasn't getting fuel for some reason. Not sure why. When I reinstalled it I tore the orange cap (looks like a wire nut almost) that I'm guessing prevents fuel from feeding back the return line. Maybe this is more important than I thought it was. :notsure:
  18. Mar 23, 2019 at 8:59 PM
    #898
    Speedytech7
    A stock truck has no obstructions to the return line that I know of. What injectors and pump are you running? Chances are you just aren't getting enough fuel because the stock tune is way too lean for boost even in open loop. But you could run an FMU as a cheap way to "tune" if your injectors are a decent size.
  19. Mar 23, 2019 at 9:03 PM
    #899
    Squeaky Penguin
    Brett
    You've always had the ADD actuator on a switch, correct? And leave it off most of the time?
  20. Mar 23, 2019 at 9:07 PM
    #900
    Reh5108
    Idaho
    This thing. It's split into a + on the ends.
    20190313_153730 by Ryan Heintzelman - Flickr2BBcode
    Stock pink injectors and the Walbro 190. I was hoping at only 5psi the stock tune would be rich enough. I think I'll go with a piggyback at some point.
